MAF Part Number differences?
Old 06-12-2007, 08:47 PM
1sennafan's Avatar
Question MAF Part Number differences?
Can anyone tell me what the difference is in the Mass Air Flow Sensor part numbers?
My screwed up one is a #22250-35060 \ 197100-2470 on a '89 4Runner 22re 5spd.
The #22250-35050 \ 197100-4051 states its for '89 to '95 22re and the cover looks the same.
On a #22250-35020 \ 197100-2470 I can see the cover is more square and is supposed to be from a '88 22re.
Do they all send the same signals to the ECU or is there a difference? I know it would be best to get the exact same part # however if I can spend less than half the money to do the same job I would rather go that way!
By the way if it matters as I found out tonight the correct air filter is for a ?88 not an ?89 because the air box is bigger and the FRAM CA6690 didn?t fit! It took the FRAM CA4830.
Old 09-01-2008, 01:03 AM
smokeyss's Avatar
I have the same problem
have u sold yours? if yes please explain how? do they match? the MASS
Old 03-04-2010, 09:43 PM
JACKOFEARTH's Avatar
I dont know if they are all like this, but i just switched out the AFM -35050 with the -35060, and it did not work. Wouldnt even start.
Old 02-13-2011, 12:45 PM
FleshThorn's Avatar
Reviving an old thread:
I just switched out an AFM -35050 for a -35060 and the truck runs the same. I don't know yet if my CEL codes are fixed, but I will in a day or so. The only difference I could find was an interchangeable bracket that is slightly different. You look for the same resistance test specs on both AFMs so I don't see why there should be any issues with how the ECU interprets the signals.
Old 09-15-2011, 09:52 AM
dmpackman's Avatar
THE NUMBERS NEED TO MATCH EXACTLY! i work at a toyota dealership and have been told this by all the certified mechanics, plus i went through it myself. I replaced mine with one that had different numbers and it ran like crap. good luck
Old 01-27-2021, 11:36 AM
Sledx85's Avatar
I'm in dire search of a 22250-35060. The 22250-35050 meters out to have a slight difference in resistance that STILL causes an issue. The only models the 22250-35060 will work for are 1988-89 4Runner 22re and 1988-89 Pickup 22re part years. Every other year / model seems to have the generic AFM. Super discouraged to find that the part I waited for from China spec'd outside the range and best match is like $900 for an exact part in or around the US.
This site has great info on the spec values. Meter Spec sheet
Old 08-28-2021, 02:59 PM
Vic4100's Avatar
What about Denso code 197100-4090? Does It really fits 22re?
larzastonia
03-23-2011 02:27 PM
mikev89
07-20-2010 11:32 AM
drew303
04-04-2007 12:37 PM
Sonofmayhem
02-05-2007 05:08 PM
JayBird
9
12-27-2004 07:08 PM
Quick Reply: MAF Part Number differences?
