Trailer Light Converter
Old 05-18-2007, 08:58 AM
Gerdo's Avatar
My factory Toyota Trailer Light Converter box burnt out. I have three options. First is to buy a new Toyota box, $111, Not going to happen. 2nd, Find someone on this forum to sell theirs that they arn't using. 3rd, Buy an aftermarket one, $35.
Does anyone have a stock converter just sitting around that they want to sell?
If I go with an aftermarket one, what do I need to do to remove all of the toyota harness?
Old 05-18-2007, 09:13 AM
frodin1's Avatar
I don't understand why these burn out so easy? I've seen this a bunch of times before on here. I guess you can wire in a napa one for less than half the cost. I'm not sure how to do it, so if someone wants to pipe in. I'm sure I'm going to need this done sooner than later with all the towing I do.
Old 05-19-2007, 06:10 AM
Mark in MD's Avatar
I've been towing with toyotas for almost 13 years now. Converter never burned out. But if it did, I would hope I could just order another one -- not have to buy a whole harness. WTF?
Old 05-19-2007, 06:52 AM
CyMoN's Avatar
I bought a plug and play one for 50$ at napa that plugs into the back of each light it was very easy get one of those much easier than the ones you have to splice wires in
Old 05-19-2007, 07:06 AM
YodaPala's Avatar
I bought an aftermarket one for about 40 bucks. I think it was made by reese? anyway works like a charm (knock on wood)
Old 05-19-2007, 08:45 AM
BruceTS's Avatar
go aftermarket, they are far better........ they are a simple to install. Get the one that is plug in play. However they are meant to be installed on the right rear vs. the left rear. I simply switched the wires and put it on the left side.
here's the type I used, I think Autozone carries this brand.
Old 05-19-2007, 10:40 AM
Gerdo's Avatar
I found a similar one at a local hitch shop for $35. I 'm going that way.
Old 05-20-2007, 08:55 PM
mpavolka's Avatar
I ended up buying a Hopkins 4Runner Trailer Converter for mine. Part# 43415. It just plugged in.
Old 05-21-2007, 10:39 AM
gpcollen1's Avatar
[QUOTE=BruceTS;50531035]go aftermarket, they are far better........ they are a simple to install. Get the one that is plug in play. However they are meant to be installed on the right rear vs. the left rear. I simply switched the wires and put it on the left side.
You couldnt have posted this a while back huh Bruce. I bought the one from etrailer.com and installed in place of the old one. Like Bruce said, it was meant to be installed in the right rear. I did not notice this until I was finished.
I suppose they do this so you do not actually have to remove the old one. So, I had to swap to of the wires so that the correct indicator light comes on when I go to make a turn....
Old 11-16-2007, 02:12 PM
ToysRus's Avatar
So, I tried to replace a broken 6-function light on my trailer. I messed up somewhere and blew the converter on my 96 4Runner. Not knowing what was up, I tried plugging the trailer into wife's Sequoia--burnt out the 4-way connector. Then (idiot), I plugged it in to our 95 land Cruiser--the Land Cruiser electrical reaked havac (blinkers stopped functioning & rig got stuck in Park...searched www.ih8mud.com and found that blown fuses in LC cause rig not to leave Park. Fixed fuses fixed all.) WELL, just got the Hoppy/Hopkins trailer direct plug in aftermarket converter ($45) at trailer supply.
HERE'S A LINK TO INSTUCTIIONS: http://www.trailerwiring.com/inst/43415.pdf
Hope this helps!
AkitaDog
09-01-2015 08:05 AM
shadowbirdie
07-21-2015 10:38 PM
crashburnoveride
07-10-2015 06:39 AM
toyota32
07-06-2015 05:42 PM
Quick Reply: Trailer Light Converter
