flywheel replacement, how much $?
Old 05-15-2007, 05:43 PM
iruny4wd's Avatar
Hey guys, I was considering buying a truck for really cheap but the guy said the flywheel is cracked and will need to get replaced soon. He already has a new one that comes with the truck. How much do you guys think it would cost just to get a shop to switch them? I'd call and check but it's too late here, all the shops are already closed. It's an auto tranny 4wd.
Old 05-15-2007, 05:56 PM
pennywize's Avatar
hmmm... an auto with a flywheel? somethin sounds strange here.
Old 05-16-2007, 03:58 AM
iruny4wd's Avatar
oops lol, I meant man.
Old 05-16-2007, 09:34 AM
eric-the-red's Avatar
I would think they'll probably want 3-4 hours labour, the trans needs to come out. And you might as well put a new clutch in, and maybe a rear seal as well.
Old 05-16-2007, 09:53 AM
X2and4X's Avatar
I would only have them check the rear seal and replace only if its leaking.
Old 05-16-2007, 10:12 AM
WFO
WFO's Avatar
How does the guy know its cracked?
Old 05-16-2007, 06:19 PM
iruny4wd's Avatar
he checked it and was planning on replacing it but doesn't have the time, he did a whole inspection on the vehicle and has a list of every little thing wrong with it. The reason I got the words mixed up about the auto is another question that I was gonna ask but wasn't sure if they have it in yota's (it's a blazer). It has like an auto 4wd thing, a solenoid activates some part of the 4wd and he said that solenoid is messed up so the front wheels wont engage right. How long do you guys think it would take to fix that doing it at home? I was just curious, I'm doing it one way or the other but I was just wondering how much labor time it was gonna take me.
iruny4wd's Avatar
Okay I'll remember that.
Old 05-17-2007, 04:06 AM
85TurboRunner's Avatar
the only way to check for a cracked flywheel is to remove the transmission, so if its already out might as well replace the flywheel yourself. i just re-read this post and see this is for a blazer? guessing an S-10 blazer with maybe a 2.8 liter engine? not worth your time unless its free.
Old 05-17-2007, 07:15 AM
norcalsvx's Avatar
i just went though this i got a marlin flywheel for $75 from marlin and a centerforce clutch kit , it cost about $160 for labor on both
Old 05-17-2007, 07:32 AM
WFO
WFO's Avatar
Not making sense why he would go through all the trouble of getting to the flywheel and not taking 20 more min to replace it.....
How cheap is it?
Old 05-17-2007, 09:26 AM
iruny4wd's Avatar
How cheap is it?
he didn't have the replacement flywheel at the time. It's an 89 s10 blazer 4.3l v6. He wants $400 for it. I'm not too sure I'm gonna take it at this point cause it doesn't have a top. I was under the impression that the top came off of those like the k5 blazers did but I guess he cut it off and doesn't have the top anymore.
Old 05-17-2007, 11:42 AM
Adam F's Avatar
You could remove the starter and see the flywheel a little through the opening
Old 05-17-2007, 01:05 PM
dcg9381's Avatar
You can't see all of the flywheel through that hole.. Might be enough though.
Replacing the flywheel is going to cost some bucks.. Not for the price of the flywheel, but for the price of pulling the transmission and transfer case. I'm guessing over $500 labor alone.
Old 09-18-2017, 05:40 AM
Diamondguy66's Avatar
2006 Nissan Altima Flywheel
I have a 2006 Nissan Altima 4 cylinder with a bad flywheel. I have a new one for it and I want to know how much anyone thinks it will cost to have someone put it in for me
Old 09-18-2017, 06:29 AM
gsp4life's Avatar
This thread is a full decade old, nice job bringing it back from the dead!
Since the answers in it apply to your car just like they did the 89 blazer, it'll still cost whatever the shop charges for a flywheel plus 4 to 5 hours labor to pull the tranny.
mskalmus
05-28-2017 07:51 AM
TURBOrunnerNM
07-22-2015 11:01 AM
1994toyota
07-17-2015 03:03 AM
KBar
07-13-2015 06:01 PM
Quick Reply: flywheel replacement, how much $?
