How does a beadlock work?
Old 03-29-2007, 07:21 PM
JulsTirn's Avatar
can someone please explain to me how beadlocks work?
Last edited by Lysmachia; 03-29-2007 at 07:43 PM. Reason: Changed title to be more descriptive
Old 03-29-2007, 07:33 PM
MudHippy's Avatar
Beadlocks pinch the bead of the tire to the rim to help hold it in place when tire pressure is too low provide enough resistance. It is accomplished by bolting a locking ring to a rim that has a seating area where the bead of the tire rests, it's like a ring that's welded to the rim behind where the bead would normally be. The locking ring is basically a circular clamp, that grips the bead against this part of the rims.
Old 03-29-2007, 07:41 PM
Lysmachia's Avatar
Pretty much what Mudhippy said. I changed your title so you;ll get more accuarate feedback Julian.
Old 03-29-2007, 09:21 PM
AxleIke's Avatar
Staun also makes a bead lock that does the same thing, but is mounted inside the tire, and can best be described like an inner tube on a bicycle.
It isn't exactly the same, but it is a tube you fill with air, and it pinches the beads on both sides of the rim.
Advantages: Balances easier, is techincally "street" legal, locks both beads.
Disadvantages: Expensive, doesn't provide rim protection like a ring will, leaving rims open to easier damage.
Old 03-29-2007, 10:40 PM
Elkaholic's Avatar
Originally Posted by Ric
good info. i never knew how they worked either, just i never really looked into one, but now i know
Dont know if you were bein sarcastic or not cuz of the smiley but if not that makes two of us!!!
ashersullivan88yota
01-18-2022 05:37 PM
sandyota
02-04-2021 11:16 AM
crashburnoveride
07-10-2015 06:39 AM
madxman21
07-09-2015 10:26 AM
Quick Reply: How does a beadlock work?
