Knocking/ Low radiator
Old 03-20-2007, 08:24 PM
crazy_horse3030's Avatar
Buddy of mine has 4 cylinder toyota tacoma. His radiator fluid level keeps dropping but he says he is not experiencing a leak. Now the motor is knocking. What could the problem be?
Old 03-21-2007, 12:42 AM
mpavolka's Avatar
Check the coolant for oil, as well as oil for coolant. This would be a head gasket, but the knocking is a little harder to diagnose.
Old 03-21-2007, 03:05 AM
MTL_4runner's Avatar
Ditto to above.
Coolant doesn't just disappear, it has to go somewhere. Tell him to pull the spark plugs and look at them. If there is one or more that is super clean (ie no brown combustion deposits), you know you have a head gasket leak in those cylinders.
Old 03-21-2007, 03:06 AM
tampabayota's Avatar
how much coolant is being lost ,and whats the time frame.remember oil and water dont mix ,so it should take a while before the coolant shows up in the oil pan. does this make sense.
Old 03-21-2007, 07:13 AM
hross14's Avatar
Check the weep hole on the bottom of the pump--sometimes it leaks from there but you dont notice--run a finger under it and see if it is wet.
Knocking--Time for a 3.4 upgrade?
Old 03-21-2007, 05:17 PM
Adam F's Avatar
Probably a massive head gasket leak, water in the cylinders, hydro locking the motor, hence the knocking.
Sleaker
08-26-2020 06:03 AM
JaredL
03-28-2016 09:08 PM
Road Bull
10-10-2015 04:55 PM
RobotMoose
Diesel Swaps
08-02-2015 11:00 PM
Jeffreynmandy
07-18-2015 08:26 AM
Quick Reply: Knocking/ Low radiator
