Front Lift Opinions Needed
Old 03-19-2007, 12:23 PM
emptypockets's Avatar
After about 2 years with stock front springs and Daystar 2.5" spacers, the springs are starting to sag. I have the LC setup in the rear, which is now giving ~3.5" of lift. I think 3" in the front would be perfect, but I don't want to run spacers again if at all possible. SAW's are out of the question because of the cost. I've done research on Tundra coils, but it looks like they give about 2" in the front, unless you do two topouts on each side, which I don't want to do either because of demolishing CV angles.
I found this link on Wab Fab's site for 3" OME front lift coils and am thinking this might finally be the solution. It's the top package that runs $209.00 with OME coils, top plate spaces and longer bolts. The link is here:
http://www.wabfab.org/96024Runner/96...iftoptions.htm
So, my questions are: has anyone used this setup? How is ride versus stock? How would this system do off road? Which shocks would you recommend? I know the owner is a member of YT and has a great reputation. Any thoughts?
Old 03-19-2007, 05:13 PM
Gerdo's Avatar
Remember, 3"s of lift (spacers, TRD w/topouts or OME) will put as much angle on your CVs. What OME spring is it? I love my TRDs (no topouts).
Old 03-19-2007, 05:38 PM
MTL_4runner's Avatar
The only way you're going to get a full 3" safely is with adjustable coilovers (SAW, King, Donahoe, etc) or a large amount of spring preload on the struts (ie very stiff setup). The Tundras will give you about 2" without spacers (you could add a topout spacer, but you'd still be at 2.5" max). Not sure which OME's Brian's got for sale. The 881's will give you about 1.25" and the 882's about 2.25" to 2.5" (you could get up to about 2.75" to maybe 3" with a topout spacer, but if you have a heavy bumper or winch, they will sag over time....and without those springs are very stiff). Bottom line is that it's very hard to get a front setup using IFS to sit level with LC coils in the rear.
Old 03-19-2007, 09:39 PM
etan's Avatar
I agree.
i think you answered your own question... the OME 3" coils with a top plate spacers seems to be the best option.
Old 03-22-2007, 05:02 AM
ozarks_Runner's Avatar
Why don't more people use adjustable coilovers for the 4Runners? Maybe it's just me, but most of the time when I see a post like this the answer given is OME/Tundra with some top outs.
I know they are expensive, but I personally love the ride my Donahoe's give me and the ability to stay level when adding bumpers, winches, etc is really nice IMO.
Sorry to hi-jack, I'm just curious since I have never used or ridden in a rig with OME or Tundras up front.
Old 03-22-2007, 05:24 AM
Hugo's Avatar
I run Downey coilovers, set at around 2". If I wanted more, I'd buy diff drop spacers, that's for sure.
Bamripzit
07-19-2015 01:17 PM
Bamripzit
07-13-2015 07:21 PM
BigArt70
06-30-2015 09:51 PM
88Toy
7
06-17-2015 09:40 AM
HALMAN
06-14-2002 09:02 PM
Quick Reply: Front Lift Opinions Needed
