Axle Code
Old 03-09-2007, 02:15 PM
Joshs98Runner's Avatar
Axle Code
I know this is a beaten subject, but I need some clarification on this matter. On sonoran steel website I found my code "vzn185l-gkpgka"
Which translates to any of these:
VZN185L-GKPGKA 3.909
VZN185L-GKPGKA 4.100 With P265/70R16
VZN185L-GKPGKA 4.300 Option
I have a 98 SR5 3.4, auto 4x4. When I bought my rig last year it had the 16" wheels with 265/70/16 tires on it, but my door sticker only gives air pressure for the 15" wheel set up. So does that mean my truck originally had 15's on it, and should have 3.909 gears, or should I go with the factory 16's it had on it, and assume it might have the 4.10, and how would I know if it had the 4.30 option or not?
Old 03-09-2007, 03:45 PM
My814x4's Avatar
Go with the tire size on the label that would be the one it came with.
Old 03-09-2007, 04:53 PM
Ironmike4x4's Avatar
On the passenger side door jamb look for the RPO code and look on Roger Brown's site for the translation.
Old 03-10-2007, 06:07 PM
That's the thing, i didn't find anything on the passenger door other than the VIN.
Old 03-10-2007, 06:37 PM
d0ubledown's Avatar
did it come with a tow package? i've got the same code, but my jamb decal says 265's. mines a LTD w/ elocker. i think the 4.30's came mostly on 3.4 ltd's (all auto's). i'd be willing to be its got the 4.10's on it...
its bloody confusing trying to decipher what gears are in what...and doing the spin & count is hardly accurate, especially when dealing with such close numbers. why cant they just put it on the ID sticker?!?
Old 03-11-2007, 07:51 AM
http://toyota.off-road.com/toyota/ar....jsp?id=274535
Old 03-11-2007, 12:24 PM
DirtyDeeds/DirtCheap's Avatar
I have a 2000 4Runner that I bought in 2003 and the jamb decal says I have P225/75R15 tires. Luckily, I found the original window sticker in the glove box. It states that I have "Upgrade package #4" which consists of,along with other upgrades, P265/70R16 tires w/alloy wheels,13" brakes, 4.10 rr diff.
Old 03-11-2007, 12:35 PM
DeathCougar's Avatar
Look on the the drivers door Jamb, or on the drivers door itself. There is a white credit card sized plate with this info on it:
C/TR
A/TM
C=Color of truck
TR=Trim code
A=Axle code
TM=Transmission code
Find that A, and let us know so we can tell you your ratio.
Old 03-12-2007, 08:55 AM
hross14's Avatar
Gear Chart
I am just went through this and i have a Gear ratio Chart from INCHWORM. I thought the same thing (3.4, V-6, 5Spd) but this is what they told me. The real test will be when i get my 3rd from them and actually read the gears. Hope this helps.
Henry
File Type: doc
Old 03-12-2007, 08:58 AM
hross14's Avatar
Edit for Gears
i mean when i pull out my old 3rd and put in the new--then i will see what i really have.
Old 03-12-2007, 09:05 AM
GSGALLANT's Avatar
A search would have found the info you need to check your gear ratio. But here's something to get you started. I explain how to check your ratio in this thread.
Old 10-08-2008, 01:23 PM
etan's Avatar
i need help and was wondering if anybody knew anything about this situation. I have a 98 4runner sr5 3.4L 5spd 4x4. I wanted to look up part numbers for carrier bearings for my detroit install. autozone and other places were asking me alot of questions that i didn't know the answers to. (what size ring gear, etc). anyways I was looking at the door jamb sticker and trying to analyze it and it only opened up a can of worms and a ton of questions.
i used these sites to help to decode it but it doesn't come up with something specific and on the money.
http://www.4x4wire.com/toyota/faq/vin/
http://www.off-road.com/trucks4x4/ar....jsp?id=274535
http://www.sonoransteel.com/Toyota_axle_codes.html
http://fleet.toyota.com/html/50/vin_decoder.asp
as you can see it says 15 inch rims, but my toyota came with 16 inch, and i've tried putting 15's on in the past but it didn't fit.
but to the main point, the A=A03A. isn't there supposed to be a letter followed by 3 numbers??? i'm trying to figure out what size my ring gear is so i can get the right carrier bearings for my detroit install. if anyone knows anything and will chime in it would be greatly appreciated.
Old 10-09-2008, 09:12 PM
MunkeyTX's Avatar
Well, I've got the same thing as you...a '98 T4R SR5 V6 5spd w/16" rims.
From the document hross14 posted:
Diff Ratio ID
If you have the axle code of your vehicle, it is easy to find out what size differential, what ratio, and what pinion set-up you have. This will also help if you are hunting for a particular unit off another vehicle. The axle code is in the vehicle ID plate under the hood or drivers door. The axle code is 4 digits: a letter followed by 3 numbers.
Example: F372 = 7.5" 3.58 final ratio 2 pinion
code:--------------------------------------------------------------------------------1ST DIGIT R&P SIZE 2nd/3rd Digit R&P RATIO 4th DIGIT PINION SET-UP
A 138mm O1 3.30 2 2 pinion
B 145mm O2 3.36 3 2 pinion LSD
C 6.25" O3 3.55 4 4 pinion
D 6.62" O4 3.56 5 4 pinion LSD
E 7.1" O5 3.70
F 7.5" O6 3.89
G 8.0" O7 3.90
H 9.0" O8 4.11
J 9.25" O9 4.22
K 9.5" 10 4.38
L 10.5" 11 4.44
M 12.5" 12 4.63
N 13.5" 13 4.79
P 14" 14 4.88
R 162mm 15 5.13
S 6.38" 16 5.29
T 6.7" 17 5.60
U 6" 18 5.71
V 10.6" 19 5.83
W 15.5" 20 6.17
X 142mm 21 6.67
Y 158mm 22 6.78
23 6.83
24 7.64
25 4.56
26 5.57
27 3.36
28 4.30
29 4.10
30 3.73
31 3.91
32 6.59
33 7.50
34 6.78
35 7.64
36 4.78
37 3.58
38 3.42
Tacomas:
The axle code for your rig can be found on the manufacture's sticker located on the driver's side door jamb as follows: First digit: A = 7.5" ring gear
B = 8" ring gear
Next two digits: 01 = 3:42
02 = 3:58
03 = 4:10
04 = 4:56
05 = 3:15
06 = 3:91
Last digit:
A = 2 Pinion, Open
B = 4 Pinion, Open
C = 2 Pinion OEM Limited Slip
some '98-00 models have shown a BO code of "???" on the door plate; so far this turns out to be a 3.91 gear ratio.
Ok, I've come to believe that the first part of the document is for earlier 4Runners and pickups, as our axle codes are not A###, but are A##A. So I've got to think that we'd fall under the 'Tacoma' listing which hits the axle codes right on the head with the A##A format. I double checked this with another site http://www.brian894x4.com/Gearratiosanddiffs.html, and their '1990 through Today' data is the same.
SO! Looks like we both have the same axle code A03A, which translates into 7.5" 4:10 2 Pinion Open diffs. HOWEVER, I'm more apt to believe that the 7.5" refers to the FRONT, and not the REAR differential after reading this page: http://home.4x4wire.com/erik/diffs/ It lists all V6 rears as 8", and to check this, Randys Ring & Pinion has this to offer: http://www.ringpinion.com/DiffDetail...%3dToyota%2bV6
Hope this helps; someone PLEASE correct me if I am wrong!
Old 10-09-2008, 09:47 PM
duel's Avatar
I looked and mine said this Vgzdual-is-#one
Hoped that helps
Old 10-09-2008, 11:40 PM
etan's Avatar
yeah i've seen that document in one of the sights. the only information that matches is the tacoma info. but i know for a fact i have a 8" v6 diff with adjuster nuts, 10 ring gear bolts and not a tacoma 8.4 12 bolt shim design.
Old 07-20-2014, 04:08 PM
SharpStick's Avatar
Axles codes give me a headache. I'd kill for a GM-style axle tag right about now...
STICK
Old 07-20-2014, 04:10 PM
If it's any help to people, I have been able to figure out axle codes for all 3rd gen 4Runners:
A01A 3.73
A02A 3.91
A03A 4.10
A04A 4.30
A05A 4.56
Those were the only available options for 96-02 4Runners.
As for Tacomas or any other type of vehicle, no clue. But those are 100% for sure accurate for 96-02 4Runners
TheDurk (11-01-2021)
Old 07-22-2014, 04:09 AM
94 Newbie's Avatar
Talking Because I like the results, you must be correct !!
A01A 3.73
A02A 3.91
A03A 4.10
A04A 4.30
A05A 4.56
'00 4 Runner 4WD w/ E-Locker, non Sport Package - A04A code.
Wonder what option package would have got 4.56's ??
Thanks !
Britt
Old 08-04-2014, 07:39 AM
Nelsonmd's Avatar
A01A 3.73
A02A 3.91
A03A 4.10
A04A 4.30
A05A 4.56
I'm late to the party here, but how are you 100% sure? I haven't read through all the old threads in a few years, but as I remember there were some inconsistencies with the axle codes and the gear ratio (as in people with the same code had different ratio's). Don't get me wrong, It'd be great if that x-reference is correct, and it does actually match mine, but it'll be hard for me to trust such a table after all the research I did on it...
I hope you really do have the holy grail here, but I have been hurt so many times in the past, it's just hard to trust again, you know?
Old 08-04-2014, 07:43 AM
I am 100% certain. I have personally checked 30+ rigs (I part them out) and compiled a list of every one and counted the teeth. For 96-02 4Runners, I am 100% sure.
Quick Reply: Axle Code
