Too much play in steering wheel
Old 02-22-2007, 03:22 PM
Lifelongtoy's Avatar
Question Too much play in steering wheel
I have a little too much play in my steering wheel. What causes that? More importantly how can I fix it?
Old 02-22-2007, 03:55 PM
GSGALLANT's Avatar
Vehicle specifics always help when you're asking a question, but assuming you don't have rack and pinion steering (which I think only came out in 3rd gen 4R's), there's an adjustment on the top of the steering gear box. Loosen the lock nut, turn the adjustment screw clockwise, then re-tighten the lock nut. Do it in steps of 1/4 turn at a time, trying it out in between steps... you don't want to tighten it too much, because your steering wheel will not "self-center" coming out of a turn.
Old 02-22-2007, 03:56 PM
Bejiita's Avatar
Worn tie rod ends would be my guess? Get it aligned its like 40 bucks :-D
Old 02-22-2007, 04:00 PM
91_4x4runner's Avatar
What exactly does turning the screw do out of curiousity?
Old 02-22-2007, 04:23 PM
GSGALLANT's Avatar
It reduces the backlash in the steering gear box.
Old 02-22-2007, 04:24 PM
GSGALLANT's Avatar
Yeah... check the pitman and idler arms for play also.
Old 02-22-2007, 05:18 PM
Thanks everyone. Getting alignment tomorrow.
Old 02-22-2007, 09:01 PM
Bejiita's Avatar
And yah what he said about tightening that bolt/screw combo I tried that before on my old truck hoping itd make the steering firmer but after it didnt I learned what it really does.
Old 02-22-2007, 11:12 PM
the_supernerd's Avatar
I also say check your idler arm. It is common for the bushings to wear in those and cause excessive play. You can rebuild them cheap if you do it yourself.
Old 02-23-2007, 10:07 AM
SwampThing's Avatar
Yep, like they said check your tie rods pitman and idler arms. Alignment will only do so much if those are shot. Gotta replace mine actually lol...
Old 02-23-2007, 11:42 AM
ToyYoda's Avatar
Check the power steering gear box pitman arm ball joint (which is permanently attached to the arm). Mine was bad and everything else was fine. I had 6 inches of play in my steering wheel. I drove like I was drunk everywhere I went trying to compensate for all the play fast enough to not drift into another lane or overcorrect and serve. I just bought a new pitman arm and everything is back to normal.
glowz825
01-25-2022 09:28 AM
Up&Down
08-11-2015 10:04 AM
terminator
07-27-2015 07:13 PM
Hamonacracker
07-17-2015 08:33 AM
Quick Reply: Too much play in steering wheel
