main bearings...to replace? or not
Old 12-26-2006, 01:02 PM
Numbchux's Avatar
OK, as some of you may know, my 22RTE had a knock when I bought it. I dropped the oil pan, and found the thrust washers, 1 of them (2 halves) was very mangled. as a result, the crank was shifted to the front of the motor probably as much as 1/4".
I pulled the main bearing caps, to find that the bearings, crank, block, and caps all passed the visual inspection with flying colors (no scoring, gouging, etc...just one side of the #3 cap was polished smooth). so today I got a strip of Plastigage to test the main bearing clearances...and find them to be about .003" (give or take .0005...). according to the FSM pdf that I have for the 22RE, the standard clearances are .0010-.0022, and the max is .0031. meaning anything over .0031 and the bearings should be replaced.
What would you do? just thrust washers? or main bearings too...I'm leaning towards just washers myself...
keep in mind, I'm doing this with the engine in the truck, so replacing the top halves of the main bearings would be difficult...
Old 12-27-2006, 01:28 AM
Ron521's Avatar
Actually, replacing the top half of the main bearings isn't difficult at all. Find a nail whose head is slightly thinner than the thickness of the bearings, and cut it short enough that it can fit down into the oil passage on the crankshaft, with just the head sticking out. Now rotate the crankshaft with a socket so that the nail head pushes on the end of the main bearing which DOESN'T have the retaining notch, so the retaining notch comes out first. Installation is the reverse of above, rotate the crankshaft the other way so that the nail pushes the retaining notch so that the notch is the last thing in.
I did this with my 89 22R, in my driveway, also replaced rod bearings while it was apart. Piece of cake!
Old 12-27-2006, 08:51 AM
maxpower_hd's Avatar
Since you are at (or almost at) the maximum wear anyway, I would vote replace them.
I would also suspect that the knock is from a rod bearing rather than a main bearing. When I ripped apart my 1993 22RE, the mains all looked fine. It was the (number 2 I think) rod bearing that was toast. It wasn't worn, it was completely gone! As in not there! The guy I got it from kept driving it after he new it spun a bearing. Then he gave the truck to me when he thought he couldn't drive it any more. I then proceeded to drive it the mile or so to my house with the loudest knock I've ever heard come from a motor.
I ended up pulling and rebuilding it. I used the crank, rods and caps from an older 22R and bought a lower end rebuild kit from engnbldr for around $350. Everything has been kosher since. Knock on wood. It's been about 7500 miles so far.
Good luck.
Old 12-28-2006, 04:56 AM
Numbchux's Avatar
well, the rod bearings are in great shape. I haven't taken the caps off, but there's zero play in them. I pried and shook, and they're very solid. but without the thrust washers the crank had shifted forward quite a bit. so I'm thinking that was the cause of the horrible sounds it was making.
well, I guess I'll order a set of mains...
Old 12-29-2006, 02:00 AM
Ron521's Avatar
If you haven't removed the rod caps to LOOK at the bearings, then you can't really say whether they are in good shape or not. Simply trying to move the rod and "feel" for play is not sufficient, as the amount of wear required to knock under running conditions, spinning at 2000-4000 rpm, cannot be felt by the human hand when the engine is cold.
If there is the slightest doubt, replace them anyway, while the pan is off. Don't be an example of "there wasn't time to do the job right the first time, but there is plenty of time to do it over".
Old 12-29-2006, 01:47 PM
Numbchux's Avatar
unfortunately, that's been the story of my life lately...except more frequently money is the deciding factor.
but yes...you're right, I should, and probably will pull the caps off (at least the 2 in the back were the knock was coming from) to ensure that they are ok. but I suspect they are, judging from the condition of the main.
I should also mention, that it was only the #3 bearing that read .003. the other 4 were .002 or smaller (the plastigage I was using only went down to .002).
Old 02-07-2007, 09:53 PM
rockdawg84's Avatar
I'm curious how this turned out for you. what did you end up doing and if the crank moved 1/4 inch was there concern that the pins in the pistons might have had a problem? Getting ready to replace both rod and main bearings with the engine in my truck in the driveway.
Old 02-08-2007, 03:42 PM
Numbchux's Avatar
Hey, I was out of town for Winter break. and then it's been below zero almost every day since....so not much has happened. I tested the other 4 main bearings, and all 4 rod bearings. finding that all 4 mains were right about at .002, so it could go either way. so I opted to replace them (I have them...but haven't replaced them). and that the rod bearings were safely inside the standard clearances. so I'm going to keep those. I've also got the new thrust washers.
I am mildly concerned about the wrist pins. but I just keep telling myself that with the length of the rod, and less than 1/4" of play at the base, that the amount of twisting force would be pretty minimal....and that the engine has very few miles on it since they problem.
unfortunately, my options are pretty limited. I'm not pulling the head unless I absolutely have to....so I'm going to replace the main bearings and thrust washers, reassemble...and see where that leaves me.
Old 02-09-2007, 10:25 AM
rockdawg84's Avatar
thanks for the update. I did both main and rod bearings yesterday. came out great and boy did they need to be done. over 200000 miles on the motor and was down to the brass in the bearings. Now runs smoth and no knocks.
Old 02-12-2007, 05:06 PM
Numbchux's Avatar
well, I didn't have the same luck. finally had time to do the work today. started it up, and it sounded just like it did before. like a freaking diesel. I just dont understand how it could show no improvement over running without thrust washers!
I did check the tolerance on a couple of the main bearings just to be sure that it was the bearings that were worn, and not the crank, and it was well within spec. maybe the wrist pins are shot, or maybe the crank is. I don't know....
Old 02-15-2007, 02:19 PM
rockdawg84's Avatar
I would vote for wrist pins because that is a forged crank from toyota. Sorry to hear about your motor.:pat: :pat: :pat:
Old 02-15-2007, 03:35 PM
Bill's Avatar
You would by some fluke chance happen to have a picture of this would you?
I've got a full bearing set sitting here, and it just dawned on me that to replace the mains I'd have to pull the tranny. That's a pain I'd rather avoid if possible(I know, not tough, just time consuming).
Old 02-15-2007, 04:53 PM
rockdawg84's Avatar
Bill
don't drop your trans. just like Ron said, do your rod bearings first, then loosen all of your main caps and get them hanging on the bolts. one by one replace the bearings, I didn't event have to rotate the crank I just used a small flathead screwdriver and sliped out the top bearing then sliped the new one back in. put the cap back on with out snugging it up and move to the next one. Once all the bearings are replaced torque the main caps starting from the center and then working out from there. easy as pie. you wont get to do the rear seal but if it is not leaking your golden. if it is leaking you have to pull the trans. Good luck.
Old 02-15-2007, 05:08 PM
Bill's Avatar
Ok good, thanks for the tip!
I'm working on this by myself (all my auto-savy friends have "jobs", and my school friends don't know a torque wrench from a c-clamp), and I wasn't looking forward to pulling the crank, let along pulling the trans alone.
Old 02-15-2007, 10:34 PM
Numbchux's Avatar
Bill
yep, it was actually VERY easy. dropping the diff and oil pan were way harder than actually replacing the bearings. it actually only took me a couple hours, to replace all the mains (already had the caps off), and put the oil pan back on.
I actually pulled all 5 main bearing caps, and laid them in order, in a box, labeling which end was the front of the motor. then replaced the top halves of all 5 bearings, and then bolted the caps up. and like rock dawg said....get them all hand tight before putting final torque on them.
I attached the FSM diagram about the order in which to torque down the mains.
Attached Thumbnails main bearings...to replace? or not-main-bearing-torque-order.jpg
Old 02-15-2007, 10:41 PM
rockdawg84's Avatar
way to go.
Old 02-14-2009, 09:56 AM
skyratcalls's Avatar
I am considering replacing the rod and main bearings in my 92 22re. The timing cover has the now infamous chain hole in it and water got into the oil. Can anyone tell me how much and where to buy the rod and main bearings? My toyota stealer wants a little over $300 +tax. Thanks
Oh, the truck has 176K, 5 speed. Have to pull the oil pan anyway to fish out the timing guides.
djpg2000
11-11-2020 04:56 AM
icentropy
09-16-2020 02:47 PM
Kalihi,HI
07-09-2015 04:29 PM
Gamble_STi
07-07-2015 07:54 PM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: main bearings...to replace? or not
