Automatic ECU into Manual
Old 12-10-2006, 01:54 PM
TexJJ's Avatar
I have a '91 4runner v6 with a manual tranmission. The ECU appears to be fried. Can I use the ECU from an automatic in the vehicle or are they totally different. I understand the manual ECU will not work in an Auto equipped rig, but will an Auto ECU work in a manual rig?
Thanks.
JJ
Old 12-10-2006, 03:37 PM
Mister Willie's Avatar
I think this was a really recent thread and the answer was yes.
do a search though cause there was some complications.
Old 12-12-2006, 05:56 AM
Yotapup's Avatar
Check post for ECU compatability.
Old 12-12-2006, 06:49 AM
mt_goat's Avatar
The problem may be physically plugging the connectors into the ECU. Pin arrangment may be different. If you can compare the EWD of both models.
Old 01-09-2009, 08:28 PM
ar design's Avatar
Has anyone ever found a solution to this? Trying to use an Auto ECU and harness in a manual
Old 01-09-2009, 08:40 PM
Guardian_Saint's Avatar
Your wire harness will not plug into the Auto ECU as stated. The auto ECU has like ten connector that connect to the auto tranny so if you can figure out the wire then you need to do some cut and splicing then it would work...
Old 01-09-2009, 08:42 PM
ar design's Avatar
I have an auto ecu + harness. I have a manual car. My question is if the Auto ECU will run engine ok without inputs from transmission?
Old 01-09-2009, 08:50 PM
All you have to do is save up some wire, like for your back-up light, clutch pedal, 4x4, start-up, and all the rest you can cut it off from the main harness then black tape over it. It should work w/o interference from the transmission.
Old 01-09-2009, 08:54 PM
ar design's Avatar
So the Auto ECU will not care if the auto trans is not there?
Old 01-09-2009, 09:11 PM
Nope.
Old 01-09-2009, 09:37 PM
tommy316's Avatar
I believe you might have to connect a few wires together so the auto ecu believes the transmission is in neutral/park so you can start the truck. I may be wrong but I know you need to do that when you swap a manual tranny into an auto truck.
Old 01-10-2009, 06:52 AM
ar design's Avatar
Any more info on this?
Old 01-10-2009, 07:17 PM
morrison's Avatar
fooling the auto ECU
I did this a year ago. It's pretty easy, the auto ECU just drives around happily thinking it's in neutral. I found all the info on Yotatech--just search. lots of people have done the auto to manual swap. All I remember is there are two big wires in the plug that have to be shorted together, I think they're white. Good luck
sanctfy
All Other Toyota Swaps
09-15-2015 02:52 PM
jbandt
08-03-2015 03:23 PM
defrag4
07-31-2015 10:50 AM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
Poncho0206
07-10-2015 06:21 PM
Quick Reply: Automatic ECU into Manual
