How tall is 265.75 R16 really?
Can some one please measure their new, or nearly new, BFG ATs for me:
265.75R16's should be approx 31.65" tall...
265.75R15's should be 30.65" tall...
Can anyone confirm or deny these figures AND are the MTRs everyone seems to be buying any good as 80% road tyres or do they wear down too quickly like BFG MTs?
I'm asking questions as I still haven't to the spare bucks to buy the BFG ATs, on steel rims, yet.
Best UK price for 6 (six) BFG ATs on white 8 spoke steel rims is: £559.30 INC VAT & DELIVERY. The worst is £950 excluding delivery! How does that compare to prices in the States?
It can vary from one manufacturer to another. I'll be mounting my 265/75r16 MT/R's next week so I'll snap some pics and take measurements. The Toy dealer has quoted me $50 for mount and balance with the Hunter machine and Haweka adapter.
Most people report 40k miles with the MT/R's - I think that is about average for a tire with such an aggresive tread. I have heard that they are pretty quiet considering their design and have a soft on-road ride. Some people steered me away from BFG because the ride was stiff and they had problems with the sidewalls being cut off-road.
That's real interesting as I favoured the BFGs for their supposedly reinforced, tougher, sidewalls. The Pirellis I run at the moment have sidewalls like soft cheese!
A lot of people were BFG devotees until the MT/R came out. The sidewall is not only reinforced but apparently the outer shell resists sharp objects so you never have to worry about the inner layers being used.
I was also under the impression that BFG's had the best sidewall but now it is my understanding that the MT/R is more resistant to puncture, and because of the rubber used, provides a better on-road ride. I was watching a TV show about a rock crawling contest and only one Jeep had BFG's (sponsored) - everyone else was running MT/R's.
See I'm having a hard time with this dimesional ratio stuff. My 31x10.5x15 are the same height as a 31.10.5x16 but when it goes on ratio WTF......is it the same ........sounds stupid but my minds eye can't comprehend it?????
The hole in the middle should not effect the hieght of the tire.......should it......no it shouldn't but then the ratio and well.......damn
When you get the P-metric tires (passenger), they give you the width (in mm), the percentage ratio of sidewall, and then rim size.
For flotation tires, the rim size has no bearing on the tire height.
For the P-metric tires the rim size is used in the calculation of finding the tire height:
265/75/16 are: (265 / 25.4) x .75 x 2 + 16 = 31.65 inches tall (calculated)
Tirerack has a good description of how to calculate the tire dimention.
Hope this helps,
Todd
The sidewall on a 265/75r15 is the same size as the 265/75r16 - just the rim is 1" larger so that makes it a 32" tire instead of a 31" tire. 265 is the width of the tire and 75 (aspect ratio) is 75% of the tread width.
Nice. Those are some of my favorite rims that Toyota ever put on 4Runners. Are you planning on still using the caps on the front eventhough you have the Aisin's? Going to modify them a little to fit?
The plastic caps from my 2nd gen wheels won't fit - but I found that the caps from a Tacoma with 15"-16" wheels will fit with a little work. They are a little small but I can bend out the mounting tabs. I bought a cheap set on Ebay but they don't have the factory metal clips - just plastic. They fit but I don't trust how hard they hold on. For now I'm trying to find the same shade of silver in a spray paint and then I'll paint the Aisin hubs and my rear axle mounting area so they blend with the silver on the wheels.
I cut my 2nd gen plastic caps in front to make them fit with the AISIN hubs. Looks almost factory.
Yes, many have reported BFG KM's to have a weaker sidewall than the MT/R. I can only imagine the AT's would be even more so, but I don't know.
I measured my old 265/75 MT/R's at 31.0" and will sit right at 30" mounted on the truck. I believe the BFG's will measure more true to the published sizes.
Many have reported to get 50,000 miles out of the MT/R.
I was just looking at Tire Rack where the KO's are $7 cheaper. I think the choice is clear being the price difference is rather moot. Not sure if that is normal or not though.
justdifferentials
Just Differentials
06-13-2022 07:40 PM
myotherrideisayoshi
09-29-2015 05:41 AM
sonorn67
09-19-2015 05:39 PM
Yotadawgjr
10
08-23-2015 10:51 AM
