dyno Software?
Old 12-21-2005, 05:47 PM
callmej75's Avatar
dyno Software?
Anyone know of any good dyno software besides desktop dyno that you can calculate hp and torque using different engine combos?
Old 12-22-2005, 05:25 PM
callmej75's Avatar
anyone??
Old 12-22-2005, 07:55 PM
DudeBud's Avatar
last i heard dtd is the only one. there is dyno 2003, but its the same as dtd but it has a few more features
Old 12-22-2005, 10:20 PM
midiwall's Avatar
Hey man...
The math behind coming up with the number is pretty straight forward. Basically you're looking at how much "work" (HP) it takes to move a given weight a given distance. There're a bunch of sites on the 'net that will do it for you... Google Search
If you're looking for something a bit more "live", then check into some of the OBD II software/interfaces that're available. For example, I use the Auterra software with a Palm box that will do the math for me kinda' on-the-fly (it computes across the 1/4 mile).
Old 12-23-2005, 04:07 AM
callmej75's Avatar
Originally Posted by midiwall
Hey man...
Yeh I figure I could do the math but I'm taking the lazy way out and letting the software do it I guess what I am looking for is something like desktop dyno where I can put in different engine combos and see where everything matches up with hp and torque. Right now I have dyno 2000 but its a little outdated. I am going to use this on my next 2 yr project and stroking a 302 to a 331 and shooting for a goal of maybe 350-380hp and 385-400ft lbs torque. Then the 4Runner should come to life with maybe an AOD behind it. But this is all preplanning stages...something to get exact numbers for when I do decide to start buying things and getting machine work done.
Old 12-23-2005, 08:32 AM
BlwnTuRD's Avatar
I use Car Tester, it lets you calculate many different things. Plus it has hundreds of vehicles in it already so it has some of the lesser known attributes put in for you; like weight distribution and such.
Old 12-23-2005, 08:35 AM
callmej75's Avatar
Where could I find this at? Whats the cost too..
Old 12-23-2005, 09:11 PM
DudeBud's Avatar
its easy to change a 302 into a 331 or what ever. frist you figure out what bore and stroke the kit has input it in and you shoule come up with whatever cubes the kit is going to make then from there figure your cam and head cfm out. here is one that i through together while looking through a summit book
Old 12-23-2005, 09:41 PM
BlwnTuRD's Avatar
CarTest2000
Here you go
Old 12-24-2005, 04:59 AM
callmej75's Avatar
Originally Posted by DudeBud
its easy to change a 302 into a 331 or what ever. frist you figure out what bore and stroke the kit has input it in and you shoule come up with whatever cubes the kit is going to make then from there figure your cam and head cfm out. here is one that i throught together while looking through a summit book
I think ya forgot to attach the kit
ChiefTetlow
08-10-2015 04:19 AM
MTL_4runner
16
01-09-2004 09:28 PM
asudan96Runner
17
07-31-2003 04:25 PM
Quick Reply: dyno Software?
