GPS & Communication Discussions here pertain to the use and troubleshooting of GPS, CB radio, and amateur radio
Cant find firewall opening to run wires through
Old 12-12-2012, 10:53 AM
billingsyo's Avatar
Hello--so my buddy got me a CB radio for my birthday but I am having trouble finding the firewall opening in my 2000 land cruiser to run the antenna/power cables through. Could someone help me?
Old 05-30-2014, 06:01 PM
Sierra946's Avatar
Need to find something already running through firewall like wire harness or throttle cable and use it as a reference. Find an open spot, double check clearance on both inside and out, drill a hole. Make sure you put rubber grommet in and silicone the cable after you push it through. This will prevent any shorts from rubbing on the metal, and any leaks through the fire wall.
Ichneumon
09-27-2015 04:21 PM
serenity03k64
06-27-2015 07:59 AM
saphirekosmos
06-22-2015 10:26 AM
Dennis140
06-17-2015 10:37 AM
Beavah
9
11-12-2013 07:31 PM
Quick Reply: Cant find firewall opening to run wires through
