Sub making weird noise!
installing a HU and 2 amps. everything works fine except when the rear sub is hooked up. The sub pushes up and down but makes a weird sound...the power is coming from a gold block that spit into 2 for the amps...thats my guess..what can it be??? help!
just thinkin again like elton says check that too, but be sure to make sure you have a good ground i had that problem before when i didnt have a large ground cable and a good ground as well
@ Ricky Astley...I'd be RIcked rolled like a mofo huh. haha
the speaker goes up and down when makes the noise. never seen this before. anyhow, I'm going to check the ground and speaker wire again. thanks
well I checked and it seems that the speakers are screwed. wasn't ripped before i took them out from my last car but w/e. might of been the wires like Elton said. well, I'm picking up a 12w32v2-d2 JL subwoofer. hopefully these don't up.
tested everthing and couldn't find the answer. opened up the amp saw some ground that off..used some foil and electric tape and its fixed. lol. thanks all.
Jeffreynmandy
07-18-2015 08:26 AM
icentropy
07-14-2015 10:23 AM
