Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
Speaker Replacement. '91 4runner
Old 07-12-2003, 07:31 PM
What are the speaker sizes for the '91 4runner?
Old 07-12-2003, 07:41 PM
Shoorty911's Avatar
Front dashes are size 4T.....NOT 4"......and the rear speakers are 5"....
Shoorty
Old 07-12-2003, 09:13 PM
Vato Loco's Avatar
Just replace the rear speakers with 6x9's
Old 07-13-2003, 04:28 PM
Where do I find GOOD speakers for '91 4runner
4t And 4 inch? Where can I find comprable s[eakers for my '91 4runner
Old 07-13-2003, 05:16 PM
Shoorty911's Avatar
The size for you front speakers are 4T......4T and 4" are technically the same size but mount differently......so make sure you get 4T for the front dash....
Old 07-13-2003, 05:27 PM
Guest
Yoter's Avatar
6x9's in the rear.
They won't fit in the panel will they? If they do then I am going to do 6x9's in my 91. I put Alpines in my dash Shoorty and they are crystal clear.
Old 07-18-2003, 12:56 AM
4t speakers?
Are 4t speakers the only speakers that will fit in the front of my '91 4runner? Regular 4" speakers won't fit? Oh yeah and where can I buy some of these 4t speakers?
Old 07-18-2003, 04:41 AM
Vato Loco's Avatar
Re: 4t speakers?
I put regular 4" inch speakers in the 2nd gen I use to have, it doesn't fit perfectly. You could only use two of the screw mounts since its not a perfect fit, but it will work.
Old 07-18-2003, 09:43 AM
Guest
Yoter's Avatar
Re: Re: 4t speakers?
I agree, the four inch works just aswell as the four T. I have Alpines down there and they are crystal clear.
Old 12-09-2005, 12:06 AM
6x9's will Fit in my 91 4runner?
Old 12-09-2005, 12:51 AM
6x9's In a 1991 4runner? Possible?
Ok so I have a nice deck but blown 15 year old speakers. I think it's about time to upgrade. I have some 4" speakers for the front but I heard that you can put 5.25" speakers up there. Also I want to put some 6x9's in the back. I do a lot of transporting so I don't have anyroom for a sub.
Does anyone know if this iss possible or know of a way to make this happen?
Old 12-09-2005, 01:38 AM
bob200587's Avatar
take the speaker hole apart and see what you're working with. I put my 6x9s in the stock spot meant for 5 1/4s. yours proabably similar to my 87 and I just put them in there and screwed in one screw. I coulda done a better job but I'm lazy and haven't had a problem with them since so I havent done anything to it. As far as the front....aftermarket 4 inch speakers barely fit in mine. I wouldnt even bother anyways....the 4s put out good sound.
Old 12-09-2005, 06:55 AM
Astralplane's Avatar
This is what I installed several years ago, unfortunately R/F discontinued the "T" model. The picture shows the 2 posts for Toyota, instead of the typical 4 posts.
http://www.carreview.com/cat/car-aud...9_1805crx.aspx
http://www.crutchfield.com/S-sQSc1ol...p?I=575FRC220T
Old 12-10-2005, 06:13 PM
Are some 6x9's flatter than others?
Old 12-10-2005, 06:17 PM
bob200587's Avatar
check the specs. there might be. The brand websites proabably have them. check between them.
Old 10-09-2007, 08:46 PM
WCorbett's Avatar
Does any one know the size of the back upper corner speakers?
Old 10-09-2007, 09:52 PM
stormin94's Avatar
Huh??? How many speakers does yours have?
Old 10-10-2007, 08:39 PM
WCorbett's Avatar
6. same as all the other 4runners lol
Old 10-10-2007, 09:47 PM
stormin94's Avatar
Not quite. Mine has four. Where are your speakers mounted?
Old 10-10-2007, 10:30 PM
rocket's Avatar
6 speakers was an option on 2nd gens. The majority have 4...
Quick Reply: Speaker Replacement. '91 4runner
