Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
Need help with my subs, losing power
Old 10-21-2010, 06:07 PM
70elcoss's Avatar
Ok guys info in my sig but the subs have been giving me problems lately. They stopped working the other day and I noticed that when I would hit a bump or dip while driving then they would turn on for a sec or two.
I parked and noticed they would once again come to life when I pulled the parking brake.
I realized the RCA cable is right below the parking break assembly so I crawled under the dash and tugged a bit on the RCA cable and the subs would come to life. So is my RCA shot? I unplugged it from the deck and connected it to make sure it was secure and still the same problem
Old 10-23-2010, 11:30 AM
myyota's Avatar
You either have bad RCA cables or a loose connection.
Old 10-23-2010, 11:33 AM
Elton's Avatar
im goin with a bad ground make sure its sanded good and tight or your rem turn on is loose
Old 10-23-2010, 11:41 AM
2DoorRunner's Avatar
As stated above, first things i would check would be RCA cables and the ground.
Old 10-23-2010, 11:57 AM
olharleyman's Avatar
I say poke your head out and make sure you didnt run aground in Scottland causing your lack of power issue.
OH Wait I reread your post and it seems its your stereo subs that are lacking power so it could be as stated above or even worse your sub/rear channel in your head unit/amp going bad bit it does sound like its the rca cables start there maybe you will get lucky and thats all it is
Old 10-23-2010, 02:59 PM
70elcoss's Avatar
alright i took the deck out to look at the rca connectors and saw nothing physically wrong with them and the grounds were all good so i took it to a local audio shop and they tested it and it turned out that the deck was bad. so i swapped it out for another one i had and it works great!
but now i ran into another problem. it seems as if theres a white plastic area thing right behind the deck and this deck is slightly longer so the RCA connections are mashed right between the deck and the back wall. is there a way to make a little room back there?
Old 10-23-2010, 03:06 PM
Heat it up and shape it differently? I dont know what part your talking about, so its just a suggestion.
Old 10-23-2010, 03:07 PM
70elcoss's Avatar
i know i wish i could describe it better but i dont have any pics so ill try to figure something out, maybe put some washers between the deck and the dash to space it out
Old 10-25-2010, 05:53 PM
drpdmazda's Avatar
you could try a set of right angle rca adapters, then they arent going straight out of the head unit, rather outa little then down.
http://cgi.ebay.com/5-x-Gold-Plated-...item3f0258ccfd
Liadrin
04-25-2022 02:54 PM
r3dfish
54
05-16-2016 10:31 PM
Liadrin
09-01-2015 06:44 AM
Esibnitsud
07-30-2015 08:19 PM
msane99
07-17-2015 10:13 AM
Quick Reply: Need help with my subs, losing power
