Front Speakers Not Working
All factory setup, CD/Tape head unit, but both front speakers are not working. Anyone else ever run into this? And yes, I have adjusted the fade control.
you can test the speakers once they are removed by using a low voltage cordless drill battery or a 9volt battery. I have a 9 volt battery with wire soldered to each terminal. by touching the wires from the battery to the speaker it will cause it to "pop" or move, in some rare instances i have seen a blown speaker pop, but not usually. if they move they should still be good.
voiddweller
19
05-02-2016 09:10 PM
