Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
2nd gen 4runner "hidden sub" ideas?
Old 02-27-2010, 07:20 AM
  #61
airkewld4life's Avatar
Originally Posted by ECMgarrett
how much space do you think the first way of doing it had?
do you think that if you had a subwoofer that didnt require much cubic feet that it'd have sounded better?
maybe if you stuffed it with the fiber stuff, would that've helped it?
just brainstorming here
i love the idea of it
Stuff the box with poly-fil. It tricks the sub into thinking the box is larger than it really is therefore giving it more cu ft of volume.
Old 02-27-2010, 07:38 AM
  #62
Brhesson's Avatar
Thanks for the links, that place has pretty good prices...i may have look into those guys. I want something that doesn't stick out into the car at all, although by the time i check clearances any 12" may have to..i'll have to see. My OZ BFB are pretty hefty...2 in a standard none ported box was well over 90 lbs. My biggest goal is to go stealth but i want to be able to camp out of the back, so space is a concern. Otherwise i'd rig something up (similar to what i have read about on here) with a removable box and stealth the Amp, etc. with Quick connects and a wire and just remove it when i go camping. But that makes it hard to jam out at the
I really think if i go 10", I'll be going JL audio or Infinity. Both hit very hard for there size. I like being able to jam out if you couldn't tell, and my 07 car came with an Infinity system that i can play distortion free up 85% volume and play basketball with friends of mine 50-100 ft away.
SADLY for me this all has to wait until i with my engine...parts still waiting though, maybe i'll screw around with the dash today....ugh
Old 02-27-2010, 08:47 AM
  #63
I wanted something that didn't stick out into the car as well but to get maximum air space with the limited tools I had to work with, that is what I had to do. It really doesn't stick out all that far. Only an 1" like I said.
If you are set on JL and don't want your enclosure in the car at all then I think you are stuck with the JL shallow mount: http://mobile.jlaudio.com/products_s...hp?page_id=245
While it is an extremely nice sub, I hope you have the dough to shell out and don't mine cutting your panel cause that bad boy is 13.5". My 10" Clarion hits very hard for being a 10" as well.
I will have no problem jamming out when I go camping. I still have lots of room for gear since I don't have an obnoxiously big sub box and my amps are mounted on the backs of my seats and out of the way. They really wouldn't fit anywhere else. I had thoughts of mounting them behind the other panel but then heat would have become an issue so I opted for the seats.
I am very happy with how mine turned out.
Old 02-27-2010, 09:38 AM
  #64
Elton's Avatar
fill the box with some poly fill it makes the sub thinks it in a bigger box
Old 03-02-2010, 10:50 AM
  #65
San Martian's Avatar
I just got a system in my runner. Focal components up front, ecliple in the rear and an 8" sub in the back. All powered by a Kicker 5 channel amp..
Old 03-02-2010, 11:06 AM
  #66
That looks really good.
Old 03-02-2010, 01:20 PM
  #67
ET
ET's Avatar
did you paint the plastic side panels black or did they come that way?
Old 03-04-2010, 05:47 AM
  #68
Previous owner painted them along with some custom wood panels and a rhino lined interior
Old 03-04-2010, 07:16 AM
  #69
Brhesson's Avatar
Wow, San Martian, that is pretty tight, certainly unique. IF those teal piped seat covers would have been a touch darker blue and i'd give two thumbs up.
Old 05-07-2010, 03:01 PM
  #70
se7enine's Avatar
That is a nice set up San, I want to eventually make a sub box out of a metal gas jug. I have seen a few and like the look of it cause you can't see the speaker if done right.
Old 02-09-2013, 09:04 AM
  #71
Haywood Yablome's Avatar
awesome write ups and good reading material!!
06-01-2021 01:51 PM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
Steezy96yota
07-06-2015 10:00 AM
HRDC0R19
07-05-2015 06:43 PM
CJ94yota
07-03-2015 10:14 PM
Quick Reply: 2nd gen 4runner "hidden sub" ideas?
