Vehicle Audio & Home Entertainment Discussions here pertain to vehicle stereo systems and home entertainment systems
1st gen 4runner custom rear seat 6.75" speaker install
Old 04-17-2012, 07:13 PM
RMA
RMA's Avatar
the stock panels are just holding the grills .. the speakers are mounted to a frame i made then used some rivets to mount them to the sheetmetal.
heres the washer removed.
Old 04-17-2012, 07:49 PM
clok's Avatar
Hey you know whats up I didnt even think they came off at the base like that , I will get to them tomorrow thank you for the picture and all.
Old 04-18-2012, 03:39 AM
cameron110's Avatar
looks good man .. but doesnt the seat hit the grill , i had mine like that and would have to be careful not to tear the grill out
My seats clear with about 1 cm to spare.
But I don't have the SR5 and I have heard the seats are bigger and more pillowy in the SR5 when compared to the DLX so there might not be as much space.
I saw your install, which looks great by the way, when I was deciding where to put my speakers and I wanted to do it that way so it looked even more stock. Especially since I park on the street in Baltimore on occasion, and the heroin junkies will knock out a window for a handful of change. God help you if you have expensive looking stuff not bolted down. But because I already had the speakers which are 6 3/4 and they are too big to sit behind the panel I had to top mount them and use the grills from the speakers. I guess I got lucky and the combo I have works, also possibly in part because the grills are pretty thin on my speakers.
Old 04-26-2012, 12:56 PM
clok's Avatar
so i finally got the rivet nut tool in the mail yesterday , so looking to finish this install this saturday , i found these washers at home depot to hold the plastic trim to the new panels.
Attached Thumbnails 1st gen 4runner custom rear seat 6.75" speaker install-door-panel-clips.jpg
Old 05-07-2012, 11:27 AM
  #25
clok's Avatar
so i finally got the panels done , and man well worth the work , the sound is so much better even thou i still need to hook up the 5 channel amp i got , the only problem i ran into was i drilled one of holes the rivets goes into a little to big so the rivet popped out when i was tightening it so i need to find out what the next size rivet is and get it inserted , but the panels are on pretty solid and the sound is amazing !!! great write up cameron110 and thanks for some of the info you provided me with .
Attached Thumbnails 1st gen 4runner custom rear seat 6.75" speaker install-1336254234853.jpg   1st gen 4runner custom rear seat 6.75" speaker install-1336261308280.jpg   1st gen 4runner custom rear seat 6.75" speaker install-1336261356569.jpg
Old 05-07-2012, 01:38 PM
  #26
cameron110's Avatar
Looks great
Glad to hear the info helped. I was going to do door speakers as well but I find that with a quality replacement for the 4" in the dash and the nice big speakers behind that I am not lacking for sound quality so I probably won't ever bother.
Old 05-07-2012, 02:57 PM
  #27
clok's Avatar
Talking
thanks, yeah i'm pretty satisfied with the big rear speakers and the 4inch up front but i'm still gonna do the door speakers just cause i'm really into sounds , just need to search and see if anyones done it on hear .
Old 02-15-2014, 09:58 AM
  #28
4.34runner88's Avatar
I believe im going to do this with my 88 4runner I love how clean it looks and the rigidity of it. it sure is better than the old panels but you can always go back if you don't like it. I love the idea about the speakers right there. I have mine in the back plastic ones where the roll bar is but the plastic is brittle after the years of sun damage. and do you have any pics of the back panels that you fabed up?? if you did those
Old 02-15-2014, 02:04 PM
  #29
RAD4Runner's Avatar
Same here. Clean install. My speakers are in same approximate location. Robust mounting but not mounted as cleanly as this. They'll stay that way until I'm done with more functional upgrades.
Old 02-15-2014, 05:16 PM
  #30
clok's Avatar
Only thing I did to the cargo area panels was paint them , but just finishing up putting back my whole dash area , got the dash pad warped in suede leather along with the gauge cluster trim piece and painting the rest of entire plastic trim pieces satin black it was a lot of work but should look nice once I'm done I'll post some pictures later.
Old 02-15-2014, 05:17 PM
  #31
clok's Avatar
Thanks.
Old 07-14-2015, 09:50 PM
  #32
what wood did you use for this and how did you secure it to the frame area??
arlindsay1992
01-23-2024 01:34 PM
4x4-runner
02-26-2017 06:42 AM
Niameyrider
06-25-2015 05:50 AM
infinityisfive
06-16-2015 06:51 PM
NerfHerder-97SR5-
11
06-13-2002 10:56 PM
Quick Reply: 1st gen 4runner custom rear seat 6.75" speaker install
