Rear Tube Bumper 98 4runner
Old 09-08-2013, 09:47 AM
ohoktimmyg's Avatar
Hey guys what's up. I recently built a rear bumper for my 98 4runner.
This is my second attempt at building anything out of tube and steel.
Heres my first attempt: https://www.yotatech.com/forums/f88/...bumper-272292/
Rectangle tube cut and notched to slip over frame:
Rough Idea:
Picked an angle:
Checking Tube against truck:
Looking at Hitch receiver and main bumper tube:
Mounting tubes cut and capped:
Figuring out shackle mounting points:
Still learning to weld:
Figured out hitch setup:
Mocking up the DP deck:
Main section in primer:
Tube sides:
CB antenna mount:
Finished:
Old 09-08-2013, 01:16 PM
wyoming9's Avatar
Red face
You need to take a drive up here some weekend.
So I can give you a very intensive hands on welding seminar
The design is good your fitting looks good from the pictures .
your welding needs some work.
It might be from using the welder you are and not enough arc time.
Overall not bad
Old 09-08-2013, 01:31 PM
ohoktimmyg's Avatar
Smile
Overall not bad
I know! I am not a good welder yet. I need more time under the hood with the mig machine. It may be the machine not being set up yet because i have never really had any real instruction on it.
I am going into my second year of welding instruction through my Local Union.. It it is mostly Stick welding.. which I am actually pretty good with(1 year of school already of all stick welding all postions..)
For my 2nd attempt ever building anything I think it turned out pretty good. at least I did it myself lol.
Old 09-10-2013, 11:13 AM
AmirK's Avatar
how much did that cost you in materials? looks super good. and was it tough to figure out the proper angles for the corner tubing?
Old 09-10-2013, 12:22 PM
ohoktimmyg's Avatar
Thanks man!
I have approx 350 into the front and rear bumpers total in material, welding wire, tube, plate, paint, etc. It is a little pricey to get the material but when you think about it, you save a bunch of money compared to buying it from somewhere.
The angles weren't too hard, and i could duplicate them if i needed too. I bent the bottom tube as one piece, but because i was just winging it I needed to adjust the angle a little bit. I cut it and seam welded it.
Old 09-13-2013, 10:46 AM
AmirK's Avatar
well done. what kind of steel did you use? i dont have access to a pipe bender so i'll probably end up doing a lot of cutting and welding corners, but it'll be good practice.
Old 09-25-2013, 10:10 AM
andersej's Avatar
What size of tubing did you use?
Old 10-09-2013, 07:01 AM
xdunaticx's Avatar
That looks awesome, What would you say you paid in metal to do the entire bumper?
Old 10-09-2013, 12:31 PM
ohoktimmyg's Avatar
1 3/4 DOM .120 Wall. Standard Tube size for roll cages etc.
Old 10-09-2013, 12:35 PM
ohoktimmyg's Avatar
Thanks
As stated earlier in the Thread, I have about 350$ in materials TOTAL, including shackles welding wire etc etc for the front and rear bumpers. (if you want to see the front look through the thread until you find the link)
If you are interested in something here on YT or other forums, a lot can be accomplished and learned simply by reading.
Old 10-09-2013, 06:11 PM
andersej's Avatar
looks great man thanks for your input!
toyota32
07-06-2015 05:42 PM
Jnkml
07-06-2015 01:20 PM
Vargntucson
07-04-2015 12:15 PM
CJ94yota
07-03-2015 10:14 PM
Quick Reply: Rear Tube Bumper 98 4runner
