OBA using your A/C Compressor and an air tank.
Old 09-30-2011, 02:12 PM
  #81
92 TOY's Avatar
nice goin'
jerk.
you ruined my trike tires.
Old 10-01-2011, 10:02 AM
  #82
BigBluePile's Avatar
Awesome!
Old 10-11-2011, 02:37 PM
  #83
ant27's Avatar
any pics of the hoses going to the pump its self?
Old 10-14-2011, 07:02 AM
  #84
As far as.......the inlet hose goes from the inline oiler/filter directly to the inlet side of the compressor. The outlet hose goes from the compressor directly to the pencil manifold that's bolted to the charcoal filter.
Easy peezy.
Old 10-14-2011, 07:45 AM
  #85
ant27's Avatar
thx gona try and set mine up today. :-)
Old 10-14-2011, 08:29 AM
  #86
Yay! Enjoy the project!
Old 10-24-2011, 11:54 AM
  #87
Update, 24OCT11
Another trail run and the system worked great!!!!
I bought a "gun style" tire inflator with a gauge and bleed off valve and that makes the process for filling tires faster. No more stopping to check what the pressure is at with a pressure gauge.
Like this:
I also installed a pressure regulator on the air hose to only push 90 psi through the inflator that's only regulated to 90 psi...
The "idle up" feature on the VSV worked flawlessly.
Only issue I had was that the inline oiler, I believe, is putting too much oil to the compressor. So, I backed it off some. The air hose from A/C compressor to the pencil gauge blew off the fitting on the compressor. That was a nice surprise.... The ATF was saturating the hose and it's getting gummy. So, I'll have to replace that hose with some more oil rated. Fortunately, DC was there and with his suggestion I added some score/gouge lines on the aluminum fitting to help the hose bite onto the fitting better.
Old 08-26-2012, 09:16 PM
  #88
Update, 25AUG12
With the motor swap done and a month gone by it was time to reattach the OBA stuff. Pretty simple considering all the parts are there
The fittings on the 3.4 are A LOT easier to work with and took a matter of a few minutes to convert. Once I got everything connected air wise I cut and spliced into the A/C signal wire to allow the pressure switch to control the compressor. I then mounted the inline oiler to the filter box. While I had the box out I put a deck plate in to allow more air in and during rainy drives to prevent water from being pulled in from the snorkel.
Bolted everything back up and tested........and.....tested......and.....nothing happened. Bob. Saget. Not getting power to the clutch on the compressor. Hmmm....time to chase wires.
Old 08-28-2012, 08:49 PM
  #89
Today I eliminated the breather filter and plumbed the inlet air via the intake tube. There was an extra port I had capped when I installed the new intake piping.
Old 09-02-2012, 06:24 PM
  #90
Charged it to 140 psi. No leaks. Aired up the wifes cars tires.
Old 09-02-2012, 06:33 PM
  #91
Also, trying to wire in the idle up feature from the 3.4. Really, the motor at idle runs just fine. No drag so I may not care. Time will tell.
Old 09-10-2012, 11:08 AM
  #92
snowshredder555's Avatar
And then....?
Old 09-10-2012, 06:32 PM
  #93
No idea, its a work in progress.
Old 10-14-2012, 07:51 AM
  #94
Gotta jumper some wires then it should work.
Old 10-26-2012, 02:12 PM
  #95
Okie dokie, so I had to repin a connector and viola! I got the A/C switch on the dash working to activate the compressor! Easy peezy
Old 10-27-2012, 04:13 PM
  #96
Also, I may move the pop off valve into the engine bay to keep it out of the elements
Old 12-22-2012, 12:02 PM
  #97
Well the pop off valve works just fine. The pressure switch I installed to turn on and off the compressor failed :/
Ordered a similar pressure rated switch but a different style. Hopefully that fixes it.
Old 12-31-2012, 11:20 PM
  #98
Installed new pressure switch, works like a champ!!!
Go me.
Old 01-30-2013, 06:40 PM
  #99
I'll just put this.....here....
Old 01-31-2013, 02:22 AM
  #100
92 TOY's Avatar
you fail, numbnuts
Quick Reply: OBA using your A/C Compressor and an air tank.
