FJ80 F/R Axles or Dana 60 and 14 Bolt.
Old 09-10-2006, 08:38 PM
yotaman's Avatar
I'm going mini axle right now. I've got a mini axle torn down in the garage ready for a rebuild.
Old 10-10-2009, 07:23 AM
Tacominator's Avatar
I don't get on here often, but found this searching... I just bought an 80 rear for my 4runner buggy for $650 shipped. It's full float, my gear ratio, disc in the rear, proper lug pattern and already has a locker that I'm wired to operate already- choice was easy for me. I don't think the offset will be a problem but you never know... Poly also makes chromoly axle shafts and with a larger ring gear I think it will fit my needs well... I don't wheel that hard, but I've broke an 4runner e-locker rear twice...
My front axle is a dana 30 which I have not broken contrary to popular belief, at $50 per entire axle the 30 high pinion has been great for me
http://azmobiweld.com/personal/personal%20index.html
Going in this:
Old 10-10-2009, 09:38 AM
mastacox's Avatar
Hey I recognize that ugly orange monstrosity
I like the FJ rims!
Old 10-10-2009, 09:41 AM
Hey brian, hope things are well for you in NM If you want a set of 4.30's for your runner (not sure if it already is) I have some for cheap!
BTW, I got 5 FJ rims for $150 and 9 of those tires for $400- this is still a budget build
Old 10-10-2009, 12:51 PM
  #25
mastacox's Avatar
Yeah, my 4Runner is already 4.30's. I'd like to go to 4.56's, but don't have the money right now.
Old 09-27-2011, 07:25 PM
  #26
hayes203hend's Avatar
def would go with the d 60 and FF14 bolt, these are my 2 favorite axles. The strength of these is insane, Ive seen them run in dump trucks to 800hrs+ mud trucks. The closed knuckle d60 fronts are junk just fyi. You can usually find 14bolts all day for a two hundred bucks but dana 60 fronts seem to be pretty penny still I can find them in wyoming for about 1000 bucks, just my 2 cents
Old 09-27-2011, 07:34 PM
  #27
GenXr's Avatar
I can't speak to the steering setup on the front 80s but you can run a double cardon rear drive shaft to get rid of driveline vibes on the rear. It's just the reverse of what the suzuki samurai folks deal with when they stuff mini truck axles under their rigs (samurais have offset rears).
Old 09-27-2011, 07:44 PM
  #28
yotaman's Avatar
WOW....... This is a realllllllllllyyyyyyyyyyyyyyy old thread.
JUICE222
10-13-2015 08:50 AM
I8URSVT
10-05-2015 07:23 PM
Toys4parts
09-26-2015 01:56 PM
Quick Reply: FJ80 F/R Axles or Dana 60 and 14 Bolt.
