fabbed a custom bumper/receiver/recovery point
had the bed off to finish welding the seam from my bob, so i decided to built a bumper/hitch from a length of 2 1/2 .250 wall square tube inserted between the frame rails that was left from the bob.
for some reason the receiver looks cocked over but i assure you this is an illusion
some grinder love here and there
hitch pin hole is pilot drilled until i can get my hands on a SHARP 5/8 bit. blurry shot
hey guys got the bed back on after trimming the roll pan to fit my new bumper
that took the longest cause i had to keep pulling the bed off and putting it back on to check for clearance ..
i had to slap the lights and tailgate on cause the bell rang. so dont mind that they are not lined up the best.
overall im happy with it
thanks for the compliments guys..
lil update.
built a yanker out of some 2x2 .250 wall tube and a 2 ton rated 8" teardrop shackle my welding teacher had laying around. plugged the end with some 1/4 inch plate and the outside retainer part is 1/2 inch plate with atleast 3 passes on each weld
its basically gonna be used to strap out my buddies from the local mud spots
this is what i ended up with
lil update.
dude, that is a freakin sweet bumper...much simpler and more functional than all the heavy-duty bumpers i've seen on here with the tubes everywhere and whatnot
also, would you mind putting up a side-shot? i'd like to see what your rig looks like with such a long bob an the low-profile bumper (trying to get ideas for mine)
Flying91
45
04-11-2024 04:39 PM
kgcwb44
01-29-2023 10:02 AM
Peevedkitten
11
08-31-2015 06:57 PM
priest16
15
08-06-2015 07:43 AM
