E-locker swap into 1980 toyota
Old 05-22-2013, 03:09 PM
blueballs1980's Avatar
Hello this is Jack, I have a E locker out of a 1998 Tacoma superchargered sr5 ( the hole third member with 4:10 or 11's actualy). Wondering what size third member it is and what axle housing I need to locate? I have a 1980 toyota 4x4 and Iv been told that the third member wont fit so I figured ill just find a Tacoma axle or anything along those lines. Any help or insight would be greatly appreciated.
And seeing as my pick up currently has 4:88's will the tacoma E locker accept 4:88's?
Old 05-22-2013, 05:43 PM
4x4YOTA's Avatar
you can modify your housing to fit... just takes some cutting, drilling, and tapping...
and yes you can re-gear, it I have an E-locker in my 81 and I had it re-geared to 4.88s using Low range off road V6 ring and pinion set and E-locker bearing set
lledwod
09-06-2016 07:33 AM
Goddamnboh
3.4 Swaps
12
05-11-2016 09:22 PM
vasinvictor
01-20-2016 12:39 PM
Crazy_Guy97
12
06-24-2015 04:02 PM
Quick Reply: E-locker swap into 1980 toyota
