Cummins 4bt, th400, 14bolt, dana 60,etc in a 99 taco
Old 07-17-2006, 03:01 PM
hamstrungtaco's Avatar
figured id go ahead and start the post on my 99 taco SAS, this is going to be a long build probably wont be finished until next fall, but aiming to get it running by early next summer, the old chassis will changed out for a new one im building, since this diesel will tear the stock on apart, heres the basic synopsis
cummins 4bt (3.9 4 cylinder turbo diesel 105 hp 320 lbs tq)
turbo 400 with B&M bandit blade stick shifter
np 205 tcase with high angle 3:1 gear set, and e-brake
14 bolt rear (4.56s)
chevy dana 60 front with
crane Cromo outer C's
dedenbear Knuckles
chevy brakes and rotors form napa
superior 35 spline axles (outer and inner)
warn premium locking hubs
spicer u joint (for now)
chevy 63" leafs
wangoneer fronts (may change)
homemade shackles and hangers, etc
bilstein 7100
chevy brake booster
f250 power steering box
sky manu high steering kit
37x13.50x16 bf goods mtrs on 16x10 steelies
custom drive shafts (high angle most likely, or savannah powertrain)
flowmaster outlaw muffler (3.5" smoke stack coming out of the tool box)
future stuff will include
bosch p1700 fuel pump
chelsea power take off and pump of somesort
hydraulic winch
Arb's front and rear
right now i have both axles, power steering box, chevy leaf springs, and about to pick up the engine in a couple weeks, like said this build will take a while, but im in no rush itll be when its done
posting the pics here, ill get some more up tomorrow http://pg.photos.yahoo.com/ph/bwarne...20%20%20%20%09
Old 07-17-2006, 05:22 PM
bruzer1123's Avatar
Can't wait to see this buildup. I read a little about those motors before. Keep us posted!
Old 07-17-2006, 06:23 PM
dragr1's Avatar
Wow, wow, wow! This may be the baddest and highest mpg Taco in the States!
Old 07-17-2006, 06:56 PM
that actually the reason why i want to do this, something different, but yet still get some decent gas mileage on 37" tires
Old 07-17-2006, 09:23 PM
yotaman's Avatar
Talking
What are you planning to do with that 2.7? I've got a 92 22RE pick-up that could use it.
Good luck with the build-up.
Old 07-17-2006, 10:10 PM
Ringmaster's Avatar
Keep us posted, this will be very interesting.
Old 07-18-2006, 06:12 AM
the whole 2.7 rolling chassis is going, manual 5 spd, all pro upper A arms with downey coilovers and add a leafs
Old 07-18-2006, 02:24 PM
couple more pics of the 14 bolt, just needs outer SRW hubs, and the A-frame hoist im still workin on for our shop (engine hoist and other uses), and the jig to build the frame on, nothing much yet, but once i get the engine with a couple more paychecks (most expensive part) i can then get the cheaper stuff and then the project will really kick into gear http://pg.photos.yahoo.com/ph/bwarne...20%20%20%20%09
Old 07-18-2006, 03:22 PM
superjoe83's Avatar
who makes the adapter to bolt up the GM trans up to the cummins?
Old 07-18-2006, 04:17 PM
id imagine advance adapter makes one, the one im getting should already have it on there, thats the awesome thing about the block is that cummins made it so that it can used in various applications
Old 07-19-2006, 09:49 AM
Ringmaster's Avatar
It depends on what the engine trans came out of.
Lots of delivery trucks, Frito Lay, Hostess Twinkies, etc. had the 4Bt mill, if it was ordered with a diesel.
And if the chassis was G.M. it has a Chevy bell housing, most delivery trucks had a TH 400 trans, some had the SM 465 4 speeds.
Lot's of old used delivery trucks for sale or auction in the web searches I've done.
Old 01-08-2007, 03:21 PM
heres the motor finally, just needs minor stuff replaced gaskets, hoses and a new turbo, but other than that its in pretty good condition
bottom of piston skirt to the end cap
the 205 tcase
torn apart
Old 01-08-2007, 03:30 PM
881stGenRunner's Avatar
been a long time since you last posted til now. you get anyting else done besides getting the engine torn apart?
Old 01-08-2007, 03:33 PM
not really, ive been kinda busy with finishing college, and working at the same time, ive been saving up for a long time for this motor, this build should progress more and more by this summer, i take that back, i did get all the brakes and outers done on the 14 bolt
Old 01-08-2007, 03:35 PM
still looks to be an awesome build-up cant wait to see it start to progress!
Old 01-08-2007, 04:04 PM
bruzer1123's Avatar
Keep us posted as you go-I am looking forward to this build.
Old 01-09-2007, 04:35 PM
TachedOutOffRoad's Avatar
dedenbear Knuckles
If youre only going to run 37s, ill trade you a built and geared yota front end for your 60
Youll only gain about of 9" of diff clearance using a yota axle over that 14 bolt.
Old 01-09-2007, 07:40 PM
well i guess i could go with 39's or 40" goodyear mtr's
Old 01-09-2007, 07:50 PM
nah my goal is to get more low end torque than a v6 and mpg than my 2.7, i changed the idea of going with an nv4500, more reliable, better fuel economy and control over an auto, heres a recent thread on one conversion in an fj80 with a 700r4,
http://forum.ih8mud.com/showthread.p...hlight=cummins
Old 01-09-2007, 08:04 PM
harpen123's Avatar
I want it!!! How awesome would it be if there was a BANKS system to match to it.
Quick Reply: Cummins 4bt, th400, 14bolt, dana 60,etc in a 99 taco
