Centering a landcruiser rear axle build
Old 01-13-2014, 10:27 AM
james92toy's Avatar
Here some pic's of a 76 fj40 rear axle which is an offset axle i made centered. Using a 76 fj housing , 1985 toyota rear housing tubes, 1992 4runner axle shafts and brake backing plate.
Im going to get some better pic's and how to later .
Cut the brake flanges off the end of the land cruiser tubes. One side will be longer .
Cut the end tubes off a 1985 toy truck housing before they taper bigger.
bolted tubes and axle on
Slide into fj housing and stop when splines come to end of spider gear.
Welded a stop to the 85 housing to set the depth of the tubes. Also you can see i drilled some holes in the land cruiser housing to weld in and keep the end of the tube strong and centered.Name:  IMG_1108_zps8945d038.jpg
Took out spider gears and put in some spacers i machined for a 1 1/4 alinement rod to line things up.Name:  IMG_1115_zpsc3e3f00f.jpg
Then bolted on some end caps i machined for the end tubes to aline with the diff and welded it up.
Put it under 4runner and welded up spring perches and shock brackets. Still need to finish welding and painting but i couldn't wait to post it up.
Old 01-20-2014, 05:50 AM
RobotMoose's Avatar
So the idea here is to run an 80-series e-locker in a 4Runner?
That's a lot of work, but the results are encouraging. Good luck!
Old 10-23-2016, 07:25 PM
ZUK
ZUK's Avatar
Almost a 3 year old thread but like what you did, James !!
Old 10-23-2016, 07:40 PM
james92toy's Avatar
Thanks , still working great !!
Flying91
45
04-11-2024 04:39 PM
jerusry
10-19-2015 05:28 PM
deepmarsh
08-06-2015 03:44 AM
hangtown88toy
07-10-2015 02:33 PM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: Centering a landcruiser rear axle build
