Can you make a 22R become a 22RE?
Old 01-05-2007, 04:45 PM
Traumahawk's Avatar
Hey guys, will a fuel injection system bolt on to a 22R motor? Has anyone ever done it? Are there any kits out there? Any info would be appreciated!
Thanks, Traumahawk
Old 01-05-2007, 04:47 PM
Keggo's Avatar
I think it would be more work than just a simple bolt on. You'd have to do a lot of wiring for the ecu and whatnot.
Old 01-05-2007, 05:22 PM
Kaleb's Avatar
Propane!
Old 01-05-2007, 11:10 PM
AxleIke's Avatar
There may also be a difference with the heads as well as the valvetrain. Not sure on that. PM Kyle 22R. that guy has done a ton of work on that engine, and knows it inside and out.
Old 01-06-2007, 12:01 AM
the_supernerd's Avatar
A 22R can be converted to a 22RE. Check out this thread:
https://www.yotatech.com/forums/f114/22r-fuel-injection-conversion-87763/
Old 01-06-2007, 03:15 AM
DestroyTheEarth's Avatar
it would cost you. either go propane (which is even better than efi if it's just a wheeler cuz you remove all the old ÅÅÅÅty wiring and sensors) or swap in a 22re. just my .02.
Old 01-07-2007, 08:10 PM
all_terrain17's Avatar
Originally Posted by Kaleb
Propane!
Hells yeah. That stuff's supposed to enable the 22R to run on its side.
Old 01-08-2007, 02:58 PM
byron4's Avatar
Propane!
doesnt propane just kill the performance? at work we have an old ford feed truck that runs on propane alone, its got a 351 V8 and we've buried it in the horse corral in mud up the the hubs and it wouldnt even spin a tire in 4-LO. i've heard of propane injection where you inject it like nitrous. is that what your suggesting?
Old 01-08-2007, 03:36 PM
Flygtenstein's Avatar
Yes you can.
There is a good tech article at offroadsolutions.com
Propane is a less efficient CH provider so power suffers.
Have you had carb issues, or is it internet hype?
Old 01-10-2007, 01:30 PM
salad_man's Avatar
I'm sure you can, but the heads are different!!! I have a 22re in my truck and had to do a head gasket change, so I did but had an almost brand new 22r head, so I put that one on... Little did I know that on the intake side there is one water jacket that dosent line up correctly so I had coolant leaking out of the fornt end of the intake side and into the engine...
sandyota
02-04-2021 11:16 AM
Doug4320
03-24-2018 10:11 PM
09-04-2015 09:27 AM
cars-guy
07-11-2015 07:51 PM
87blyota
07-10-2015 04:31 AM
Quick Reply: Can you make a 22R become a 22RE?
