Bumper Idea -- need input
This may be a poor image, but it's all I have at the moment and I wanted to start generating some feedback. This will be going on my '87 runner and I'm planning on putting a tire carrier on as well. Will try to keep this updated with design revisions/additions. Main part is 2x4, sides are 1/4" plate.
1/4" plate is going to be WAY heavy and WAY overkill. Use 3/16" and enjoy the lighter bumper. It will still be strong enough- just use 1/4" for your mounting plates.
Looks pretty good though.
Edit- Also, start thinking about your tire carrier ASAP. depending on how you do it, it could really change your design. (i.e. swing arm mounted on top, to the face, trailer spindle, bushings etc.)
I agree with Ardent about using 3/16 over the 1/4. I built mine out of 3/16 and banged it pretty good wheeling and havnt damaged it at all. Also I would leave a good gap between the body and bumper 1/4+ . Mine I built at 1/8 gap, looks good on the road but has chipped the paint when flexed or after slidding on some rocks. Just my opinion tho good luck on the build!
Thanks for the input! 1/4" on the sides may be overkill, but it's material I have laying around. I might see if I can scrounge up some 3/16" stuff though just to shave some weight since the tire carrier will be adding a lot of weight. My hope is to have the sides close to the body, but probably something like 1/2"-1" offset so that they won't flex and hit. Here's an updated version showing the tire carrier roughed in.
That looks cool, but ya that looks heavy especially if your carrying an off road tire. Something like an A bracket would stand more weight for your spare. Good luck with the build!
The carrier will be an A frame or triangulated in some fashion and will be supported on the latch end, I just haven't gotten around to drawing those parts yet Also, I was planning on using the Iron Pig hinge and putting it in a sleeve thinking that may work somewhat like a double shear design.
Looks good! Like your concept. Can't wait to see more. I would suggest a different mounting method for the hinge. Mounting to the plate will be placing alot of forces ont he plate. Might lead to a shear failure. I would suggest placing the hinge within the plate so that their is more structure to hold and support the weight. The greatest force will occur when the carrier is swung out. can't find the pic right now, but do a search for "Fat Mouse". Those guys came up with a very good design that is well thought out.
My $0.02 worth.
Mark
My $0.02 worth.
Mark
The center section is 2x4 tubing. Only the side protection is plate. I've still got some details to work out on the carrier mounting, just have to find time to test them out.
WTB[WestCanada]: 1989 4runner stock front bumper and other items
lledwod
08-30-2016 01:03 PM
dinks07
07-15-2015 05:34 PM
