4rnnr33's 94 excab build
Old 11-11-2010, 10:18 PM
4rnnr33's Avatar
Well some of you have probably seen my 4runner build on here and I ended up having to sell my tow rig so the time came to get rid of the runner and build somthing more streetable. I ended up selling the bare cab and frame motor and tranny from the 4runner and kept everything else for this build. Here are the specs:
TG 5" sas- DONE
TG 5" rear kit- DONE
83 front axle
High pinion w/ 5.29s and detroit- DONE
Armored trussed and gusseted- DONE
30 spline longfields and hub hub gears- DONE
TG trunion eliminators- DONE
ARP knuckle studs- DONE
3rd member stud eliminators- DONE
V6 calipers- DONE
Marlin HD seals- DONE
Rear axle: V6 3rd with 5.29's and lockright- DONE
Sky t case e brake- DONE
Dual stock cases- NEEDS INSTALLED
Twin Sticks- NEEDS INSTALLED
Bed bobbed 12"- DONE
HID headlights- DONE
Rock sliders- NEEDS BUILT
Bumpers- NEEDS BUILT
37" BFG Krawlers on 17" black steels
So thats what ive got so far tomorrow im going to finish up the body work for the bob and then im going to start planning out a rear bumper.
I havent taken alot of pics because its been covered a million times but heres what i have
In the process of cutting out the ifs
Sitting on its own weight
Suspension all done
In the process of the bob
More To Come!
Old 11-11-2010, 10:26 PM
DeathSycthe02's Avatar
dude this is sick good work
Old 11-12-2010, 09:45 AM
4rnnr33's Avatar
Thanks man
heres some pics of the bed all welded up just need to do the body work
Old 11-12-2010, 10:03 AM
irab88's Avatar
looks like a hilux disguised as a pick-up. nice!
Old 11-12-2010, 06:08 PM
4rnnr33's Avatar
heres some updates
got the body work pretty much done still needs a little more but that can wait until i paint it next summer
Old 11-12-2010, 07:57 PM
Sponsor
Tofer's Avatar
Subscribed!
Old 11-13-2010, 05:07 AM
irab88's Avatar
that's a nice big area for you to work! is it yours or are you just borrowing space?
Old 11-13-2010, 11:57 AM
4rnnr33's Avatar
Its my grandpas shop im lucky enough to get to use his shop and tools pretty much whenever i want. If I didnt have his shop as an option then I probably wouldnt be able to do hardly anything to my truck so its really nice.
Anyways I got the sky t case ebrake installed:
The clearance between the rotor and the vss is super tight I had to pull the wire as tight as I could and zip tie it back to keep it from rubbing
Thats all for now
Old 11-13-2010, 12:20 PM
irab88's Avatar
wow, that's tight behind there. how do you like the e-brake setup?
Old 11-13-2010, 03:10 PM
4rnnr33's Avatar
Works awesome it will kill the truck if i try to take off with it on
Old 11-13-2010, 05:54 PM
irab88's Avatar
"kill" as in stall out? or "kill" as in need a new transmission and crankshaft?
Old 11-14-2010, 09:58 AM
4rnnr33's Avatar
stall
Old 11-14-2010, 10:12 AM
ChefYota4x4's Avatar
Sweet, 4rnner33! Great work, I really LOVE your truck....and chop-skills! lol.
Old 11-14-2010, 10:14 AM
bobby_duce's Avatar
looks good, i love that color too!
Old 11-14-2010, 10:26 AM
X2! lol.
Old 11-14-2010, 10:31 AM
bobby_duce's Avatar
its purdy! lol
Old 11-14-2010, 11:10 AM
dannomite's Avatar
Just a thought for the pivot on your sky brake. It looks like you could flip the bolt so that the treads are pointed at the truck instead of the ground. That way you won't bend the end of the bold over on a rock. That said, there may be a reason for it going that way. In either case the truck is looking awesome. Keep the pictures coming.
Old 11-14-2010, 11:38 AM
4rnnr33's Avatar
Thanks for all the comments!! And about the bolt I didnt even think about flipping it until I was looking at the pictures so when I get around to it I'll flip it but it shouldnt be seeing anything but snow for a while so I dont think it should be too much of an issue.
Old 11-14-2010, 11:47 AM
irab88's Avatar
one more e-brake question: on the site it said 1 hour to install, but how long did it actually take you?
Old 11-14-2010, 12:03 PM
87hillbillyoter's Avatar
pretty sick build man. how do you like those 5" springs? i was thinking about 4" because i thought the 5 inchers would be too tall, but now im thinkin about em again.
Quick Reply: 4rnnr33's 94 excab build
