Vendor Advertising Vendor's, use this area to alert members to your OEM & Aftermarket Toyota parts
Where to buy Flamethrower 89-95 22RE 4-hole upgrade injectors
Old 07-28-2013, 09:32 AM
FormerVendor
Flame Thrower's Avatar
Hello all.
I am currently selling the Bosch 4-hole upgrade injectors on ebay. These are the best injectors on the market for your stock or modified 22RE.
Click on the image to go directly to the auction.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=261228451440&ssPageName=STRK:MESE:IT
Please have a look and watch the videos on the ebay listing.
Test and review of the injectors from from yotatech member Toyota~Boy:
https://www.yotatech.com/forums/f199...9-95-a-271478/
Curtis
888-621-0794
Old 08-01-2013, 11:37 PM
jlw19882's Avatar
i would like to test a set ive got a built motor and therese would be awsome in my truck heres a link to my vid would gladly support ur product if you are intrested message me on you tube thanks hope to here from you thanks jonathan
Old 10-29-2013, 05:57 PM
instantninja's Avatar
Hi, just curious if you do other injectors as well. I've got some 295cc( i believe that is the stock flow rate for the yellow top 7m injectors) injectors on my 7mge swap.
from the sounds of everyone that has swapped out to your injectors its worth while.
If you do, I have 2 set
thanks,
Guy
Old 01-06-2014, 03:59 PM
4running22's Avatar
is it $100 for all 4 or just 1?
Old 01-06-2014, 04:14 PM
FormerVendor
its $100 for the set of 4 delivered w/gaskets and harnesses.
Old 01-11-2014, 09:13 PM
4running22's Avatar
i have an 85 22re..is there any way these would work or are you gonna be coming out with ones that work with older gen 22res?
Old 02-28-2014, 05:17 PM
92yoterDD's Avatar
I just purchased a set of your injectors through your Ebay page. I stumbled across them earlier today during a google search and then found your thread here so i thought i would register. I am looking forward to installing the new injectors with the freshened up motor.
Old 03-29-2014, 06:39 PM
Daddyota's Avatar
Will 89 4runner 22re injectors work on my 86? I can't seem to find anything in difference except the connectors are different- and you replace the connector as well right?
Old 03-29-2014, 06:49 PM
FormerVendor
no i carry 84-87 22RE injectors. here is the link:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=261238752845&ssPageName=STRK:MESE:IT
send me a email to flamethrowerinjectors@gmail.com and i can work out a deal for you.
curtis
Old 01-04-2015, 12:00 PM
1yota91's Avatar
22re injectors
I just ordered theses today. I had an upgraded set of injectors in my truck already but the keep messing up and the return policy was stupid they wanted me to take them out send them to them as my truck just would sit in my driveway and do nothing and that's my DD. they where the yellow ones. theses ones seem to be pretty much the same but from reviews seem to be reliable so Im going to give them a try and hopefully have to luck with them.
Old 01-04-2015, 02:23 PM
chosenchange's Avatar
do you have sets for the 85 22re?
Doug4320
03-24-2018 10:11 PM
mskalmus
05-28-2017 07:51 AM
steve miller
10-10-2015 01:40 AM
deepmarsh
08-06-2015 03:44 AM
Nailit69
Diesel Swaps
07-21-2015 05:28 PM
Quick Reply: Where to buy Flamethrower 89-95 22RE 4-hole upgrade injectors
