Vendor Advertising Vendor's, use this area to alert members to your OEM & Aftermarket Toyota parts
Tacoma/4Runner 2.4L/2.7L Mini-header kit now available!
Old 05-20-2010, 07:08 AM
  #61
marvintheminnow's Avatar
it looks like whoever provided the intallation photos never reinstalled the heat shield. was this for photo purposes only because they had reassembled everything above the heat shield?
marvintheminnow is offline
Old 05-20-2010, 07:54 AM
  #62
Staff
DeathCougar's Avatar
The heat shields are different between the two types of manifold/header. One would have to modify the manifold heat shield to fit the later header, so what people often opt to do it just use header wrap. I believe Scuba modified his stock manifold heat shield to fit the header.
DeathCougar is offline
Old 05-20-2010, 08:55 AM
  #63
so im running a risk by leaving it off?
Old 05-20-2010, 08:58 AM
  #64
the shield is kinda of a pain to remove and inthe process i pryed the tranny dipstick out of position and lost the bolt that holds the dipstick into position. anyone know what size bolt i need to pickup to replace that?
Old 05-20-2010, 09:04 AM
  #65
scuba's Avatar
Correct. There's like 2 spot welds / rivets I drilled out, and drilled an extra hole or 2 in the heat shield and the heat shield then fit like it was stock.
scuba is offline
Old 05-20-2010, 10:50 AM
  #66
so if and when i need to do this job i can find a used heat shield off a newer rig with the mini header setup that would bolt up to yours?
Old 05-20-2010, 11:00 AM
  #67
Staff
Yes, you can find a heat shield from a 2001+ Tacoma 4Cyl and it will bolt up, since our kit uses OEM parts.
Old 06-20-2010, 07:14 PM
  #68
Staff
Another kit sent, another happy customer
Have a kit in stock, and it can ship monday!
Old 07-12-2010, 03:36 PM
  #69
Staff
Bump!
Kit on the shelf, ready to ship
Old 08-22-2010, 07:56 PM
  #70
yotaman85's Avatar
I might be picking up a tacoma this week. if I do you'll get a call from me first thing. the wife already approved!
yotaman85 is offline
Old 08-23-2010, 06:43 AM
  #71
Staff
Have the kit in stock, ready to ship
Old 08-30-2010, 04:48 PM
  #72
N2Frodn's Avatar
Just went and checked my tacoma. Sure enough, two decent sized cracks (Dammit!). Thought I heard an exhaust leak, was hoping it was just a collector gasket.
Does the mini header work on a 96 5 lug truck with a 2RZ? (I imagine it would).
N2Frodn is offline
Old 08-30-2010, 07:13 PM
  #73
Staff
Yes, the 2RZ and 3RZ manifolds are the same.
Old 09-21-2010, 01:13 PM
  #74
Staff
Bump to teh top
So far sold 15+ kits and ZERO issues! These things fix you right up!
Old 09-30-2010, 04:22 PM
  #75
pendrag's Avatar
I imagine I'll be picking one up once I scrape together the funds. Just found this today:
pendrag is offline
Old 10-22-2010, 01:14 PM
  #76
Staff
Sent another kit out today!
I know there are more cracked manifolds out there!
Old 10-28-2010, 06:25 PM
  #77
brutalharmonies's Avatar
Yep , hoping it gets here by tommorow ) will keep ya updated as to how everything works out .
brutalharmonies is offline
Old 10-30-2010, 01:07 PM
  #78
This arrived EXACTLY when it was suppose to , I would definately order again from this guy/company , everything was as described , don't hesitate to splurge on this . I Painted the headers a silver color with VHT paint and man does it look good , now all i have to do is wait on pb blaster to soak in to start this project . I am planning on modding my heat shield to fit this as well .
Ps . The only problem i have is the kit didnt come with the EGR gasket , for 325 dollars i think you guys should just put the egr gasket in there too. No biggie tho.
Thanks ......Mh
Old 10-30-2010, 03:29 PM
  #79
Staff
Thanks ......Mh
I thought about that yesterday, and I think I may start doing that.
Old 11-12-2010, 11:36 AM
  #80
Staff
2 more kits went out this week.
Currently have one in stock, ready to ship!
Quick Reply: Tacoma/4Runner 2.4L/2.7L Mini-header kit now available!
