Vendor Advertising Vendor's, use this area to alert members to your OEM & Aftermarket Toyota parts
Old 03-29-2016, 01:00 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Toyota 4Runner Specifications & General Maintenance
Print Wikipost
The most complete 3rd Gen 4Runner lift kit ever offered: Featuring Tundra TRD coils
Old 06-28-2006, 01:47 PM
  #81
sschaefer3's Avatar
There are parts in this kit that took a lot time and R&D to come up with solutions for, this is one of those parts.
We have also had a lot of problems in the past with intellectual theft, the descriptions are left vague on purpose, the bottom line is the kit contains everything you need and nothing you do not.
Certain parts that only we make and offer are not pictured and use vague descriptions. This is a reaction to what has happened in the past.
Old 07-18-2006, 09:35 AM
  #82
sswearin1's Avatar
Hey Steve, I recently bought a 2.5 kit that shipped about two to three weeks ago, but I don't believe it included the conversion disks. Is this extra? How much and can I get them separate because I purchased a kit from you? Thanks.
-Steve S.
Old 07-18-2006, 09:59 AM
  #83
sschaefer3's Avatar
-Steve S.
Look on the top of the rear shocks, they are on them, on top and below the rubber bushings.
If you have any more questions, just e-mail me.
Old 07-18-2006, 01:50 PM
  #84
sswearin1's Avatar
cool. that's it, I have to say, your instructions and little extra you put into your kits are awesome! can't wait to put it on.
Old 07-18-2006, 01:53 PM
  #85
sschaefer3's Avatar
The only other thing I would add is that you may want to pickup the 38mm studs and put them in durring the inital install, that way if you want the extra 1/2" it is very easy to add instead of hard.
At this point I am steering most everyone to the kits with the top out spacers as that lift does sit more level.
If you want to add that I will just charge you the difference between 1 and 2.
Old 08-06-2006, 06:00 AM
  #86
sschaefer3's Avatar
I bought all of the Tokico Trek Master shocks they had in the US. There are more here now, but they have to print boxes for them.
Hitachi also just bought Tokico so there are some changes going on. Bottom line is I am not going to be able to ship any kits out for a few weeks.
I'll update this when the shocks start flowing again.
Old 08-17-2006, 05:20 PM
  #87
lr9788's Avatar
i am considering purchasing this kit sometime in the near future and was wondering what the shipping cost would be for option #2 to 37069
Old 08-17-2006, 05:56 PM
  #88
sschaefer3's Avatar
Once you hit this weight around 85 pounds, it's pretty much the same cost no matter where it goes. Around 70-80 dollars.
UPS Ground & Insured.
Old 08-17-2006, 06:22 PM
  #89
lr9788's Avatar
well upon further reading of your website i have discovered that none of your 2-3" lifts are available for 2wd
Old 08-17-2006, 07:30 PM
  #90
sschaefer3's Avatar
That is correct. You have a slip yoke and if you lift too high it will pull out too far.
Old 08-17-2006, 08:11 PM
  #91
lr9788's Avatar
so what is the highest suspension lift i can put on a 2wd 4runner before i pull out the slip yoke too far?
Old 08-17-2006, 08:41 PM
  #92
sschaefer3's Avatar
All I have for 2WD trucks is System 3 and 4. Anything over that I am not willing to provide support for.
Old 08-17-2006, 08:45 PM
  #93
lr9788's Avatar
i appreciate you not just selling a product that you know will cause harm to my 4runner. i am really wanting a lift just for looks, so do you know of anywhere that i could get about a 2" or 3" lift? i am not a fan of the body lifts
Old 08-17-2006, 08:50 PM
  #94
sschaefer3's Avatar
No I do not.
Here is some heavy reading for you:
https://www.yotatech.com/forums/f2/ome-lift-installed-driveshaft-vibration-51725/
No kidding.
Old 11-20-2006, 05:51 AM
  #95
sschaefer3's Avatar
FWIW no one is going to sell you the stock parts as low as you are getting them in these kits. These kits also are a complete solution. You will need nothing else. If you track down part numbers and try to assemble the kit yourself, you will find the rear shocks do not bolt in, they are too long and you will smash the guts out of them and your rear sway bar will get bent. That's just a start.
Installing 80 coils without our kit will destroy parts on your vehicle.
Old 11-20-2006, 07:35 AM
  #96
sschaefer3's Avatar
Originally Posted by emptypockets
I installed just the 80 series coils about 6 months ago and haven't had one problem with it yet. Granted, I don't often wheel, and I do understand the need for your complete setup for those that do. The stock length shocks limit droop, so after thorough testing, my brake lines and e brake cable do not stretch because of the shocks.
Well yeah, but isn't the entire point of lifting your truck and then ADDING the same travel back? So you have added ride hight and the same droop as stock? All you did is lift it and hold it all back down with your stock length shocks.
Why did you even post this? I don't get it. This is a vendor add in the vendor section.
Old 11-20-2006, 12:59 PM
  #97
emptypockets's Avatar
Sorry, post deleted.
Old 02-03-2011, 07:25 AM
  #98
Samuel_Adams's Avatar
Can any of you gentlemen help me with a few questions? I'm currently stationed in Japan and here the 4Runner is known as the Hilux Surf. I'm looking to get a decent sized lift for my 1996 3.0 turbo diesel 4X4 and I'm curious if this kit will work on my truck? And will yall ship here? It's an APO address so it's technically a U.S. address. Thanks for the input!
Sam
Old 02-03-2011, 03:05 PM
  #99
AZ4ME's Avatar
This is an old thread. Go to Sonoran Steel's website and ask them the question directly.
AustinTaco
08-22-2022 10:45 AM
live4soccer7
09-03-2015 12:29 PM
bowhunter1640
07-06-2015 08:10 PM
rondogracing
07-05-2015 12:32 AM
Niameyrider
06-25-2015 05:50 AM
Quick Reply: The most complete 3rd Gen 4Runner lift kit ever offered: Featuring Tundra TRD coils
