89-95 22RE/3VZE upgrade fuel injectors -free-
#42
your stock injectors do an OK job. but having a better spray pattern makes a large difference in part-throttle driving, which is all most of us ever do.
your engine burns fuel vapor, not raw fuel. the closer the fuel is to vapor in the first place, the better. you get a bigger, harder bang with a cleaner burn that gives you more power and better throttle response. its not magic, it's combustion physics.
#44
sent you a pm a couple days ago but figured I should it here. This is an amazing opportunity so if you decide to pick me for one of these sets I would be incredibly grateful Thanks!
#45
My assumption would be that you would actually see better smog readings. The additional power is coming from a more efficient spray pattern and therefore more efficient burn, instead of just adding more fuel and air like most power additives. Therefore you would need less fuel for the same amount of power and should see better smog numbers as a result.
#46
#49
#52
give me a call at 888-621-0794 and i can get you a set.
#53
the 88 is a stand-alone year for the 3vze injectors. it requires the early style (low ohm) injectors with an adapter harness to mate it to the 88 wiring harness. i don't have them listed because too many buyers bought them in error and the injectors killed their ECU.
#57
I don't have the required 50 posts as I mostly just read and learn. I need all new injectors for my 89 22re pickup. Would you please tell me where I cn purchase them on ebay if necessary?
Thanks,
Rick
Thanks,
Rick
#58
