Stronger CV Shafts
Originally Posted by colsoncj
thanks guys, would you recommend the upgrade? Running 33s at the moment, 35s soon, and locked up front.
I have heard that 35s are the max size IFS can take. I think you are risking major breakage with that size, depending on what you do.
Holy Sh** they're that much. No way. I can get some lifetime ones from the parts store I used to work at. If i break them I get new ones for nothin. Man I love havin a parts store in the back pocket.
Forget about the stronger than stock crap, save your money. Just get some replacement axles, and go with that. I have broken 3 ORS axles (which are supposed to be stronger, yeah right). So, now I'm back to the Taco V6 Manual hub axles.
I have only broke 1 so far, but i think age had more to do with it than anything else. I'm just going to keep the stock CV's with the warranty. works for me and is a whole lot cheaper!!
the CVU axles come with a lifetime free replacement warranty too, i am interested to see how far i can push these. i would have never spent the money on them either but the guy i bought the parts from to do my manual hub swap did!
The only problem with they're warranty is you may have to ship them back, then they'll ship you new ones. With the local parts store's shafts, you break them, take them off, go to the parts store, and you get new ones...
i don't know how much faith i would place in the ones you can get from parts houses anyway, there are several board members who have had bad experiences with those. ask paul bratik what he thinks of them.
Claiming 30% stronger than stock is a big claim with no practical gain.
A reman'd is a crap shoot, but a cheap one.
I sure would not invest in aftermarket CV's if I was breaking only once in a blue moon. If I was breaking regularly, I would get CV"s off the truck.
The parts store I go to doesn't only have remaned... they also have new shafts, price difference is only 40 bucks more. I can get them same day too. (Warehouse has a bunch and is in the same city.)
thats what i do when i snap one, take it back to autozone for them to replace. just carry a spare on the trail. get yourself a good pair of snap ring pliers, and then grind the splines off the 6 bolts holding the shafts to the inners. i also dont use the bolt and washer inside the hub, just the snap ring holds it in place. that way its just a matter of removing the 6 nuts holding the hub on and then it comes off.
changing a CV shaft for me consists of:
unbolting and removing locking hub
removing snap ring
removing 6 CV to inner shaft bolts
removing whats left of CV shaft.
put the new shaft in
put 6 bolts in
put snap ring back on
put hub back on
thats about as fast as it gets
removing snap ring
put 6 bolts in
put hub back on
I haven't checked into this much, but since a couple of you have mentioned that you carry a spare on the trail: are both sides the same? If not, do you carry a spare for both sides? can you run the truck without a shaft to get you back to base?
