Man! I broke a needle bearing
Old 10-31-2006, 02:29 PM
Crazychopstick's Avatar
I accidently broke a needle bearing on my rear driveshaft's double cardan joint.
What should I do?
Old 10-31-2006, 04:46 PM
Doc279's Avatar
Huh - replace it !!
Old 10-31-2006, 06:24 PM
Originally Posted by Doc279
Huh - replace it !!
I wasn't aware you could just buy these at a store.
Old 10-31-2006, 07:28 PM
snap-on's Avatar
how do you break a needle bearing?
your talking about the needle bearings in the ujoint caps?
so replace the ujoint.... find a needle bearing out of an older joint?!?!
Old 11-01-2006, 06:52 PM
I broke a roller bearing in the CV ball joint.
Old 11-01-2006, 07:38 PM
Napoleon047's Avatar
go to napa and get a centering ball kit, replace and go
Old 11-02-2006, 01:16 PM
Do I need to know who the manufacturer of the bearing is and part #s?
Old 11-02-2006, 07:58 PM
no, they look it up by application. tell them whatever year truck its from and they will get you the proper kit.
Old 11-02-2006, 08:20 PM
You're wrong.
I guess the '97s are still too "new" to be rebuilt.
There's not a listing for a center ball rebuild kit. They have them. Just not in for my model. All they have are U-joints.
Now I'm wondering which CV joints can change over. I know for a fact that U-Joints for the front CV on 84-94 Toys are the same as the rear CV on my '97.
Old 11-03-2006, 05:19 AM
sounds like you are in for a trip to the dealership then
Old 11-06-2006, 03:31 PM
Yeah, they're not going to have it. They don't deal with driveshaft work. They only replace the whole thing.
I found a similar diameter one at a local bearing shop.
It's a little shorter (about 1/4 less in length) but it works.
Drove around today and I did hear a light grinding sound of sorts from the driveshaft but at least the original problem(U-joints) is gone.
Any safety issues here guys?:pat:
Old 11-15-2012, 12:55 AM
91_Hilux's Avatar
how many needle bearings are there supposed to be in the double cardan cv ball joint?
06-01-2021 01:51 PM
oldirtydirt
02-23-2020 09:30 AM
wberry85
04-06-2018 08:45 AM
choppe777
05-16-2016 08:00 AM
G-off
12-29-2015 12:44 PM
Quick Reply: Man! I broke a needle bearing
