Lock Right Identification
Old 03-30-2005, 04:16 PM
surelly09's Avatar
GOT IT NOW!!! I thought maybe it was some sort of LSD....well guess i am SOL.... need to get how on ebay!!!!! LOL... need to sell my 4cyl lock right too..lol
thanks EVERYONE for your help. I appreciate it...
Old 03-31-2005, 05:47 AM
leiniesred's Avatar
The Gxx5 diff carrier (LSD carrier) DOES looks like the Gxx4 (4 pinion, v6/turbo gear carrier) from the outside. You can see that it is a LSD by looking in the axle holes. See a grid pattern? That is one of the clutch disks for the LSD. See the center of the 4cross pin? It is an open 4 pinion diff.
You are right, 4pinion V6/Turbo carrier and the 4pinionLSD carrier do look the same in the pics, but that isn't one. Another way to tell is by where the gear mounting flange is. It is about .25 farther from the pinion on a supra Gxx5 LSD.
I kinda knew you would be dissapointed to find out you had the wrong lockright.
no big deal. In fact, the lockright install in the 4 pinion diffs is EASIER IMO than on the 2 pinion diffs. No need to pound out that cross pin retaining pin and remove the RING GEAR like on the 2 pinion carriers.
Old 03-31-2005, 11:05 AM
surelly09's Avatar
OK found a guy who will rebuild my diff with new Timken bearings, New YUKON 5.29's, trade my 4cyl Lock Right and install a 6 cyl Lock Right for $540.(including return shipping) Does that sound reasonable?
Old 03-31-2005, 10:34 PM
surelly09's Avatar
no one has any idea what a good rebuilding price should be....
Old 04-01-2005, 03:48 PM
  #25
superjoe83's Avatar
i set up my own so i wouldn't know what it would be, but 540 sounds reasonable
ladybugRC
458
08-21-2020 10:41 AM
PNW94Runner
09-29-2015 02:55 PM
toyotasaurus
09-24-2015 03:30 PM
Jason4X4
09-17-2015 08:02 AM
zz_denis
09-06-2015 03:43 PM
Quick Reply: Lock Right Identification
