Lift needed for 35 inch tires
Old 12-11-2006, 01:20 AM
Numbchux's Avatar
my truck came with 31s on it, with a little extra tension on the torsion bars, and an add-a-leaf in the rear (~1" or so of lift). I figure I should be able to replace the torsion bar tension with a 1.5" BJ spacer, maybe a slightly longer shackle in the rear, and a 2" body lift. and fit 35s without too much fender trimming.
the 35s would only be 2" closer to the body than they are now. I think a little over 2" of lift over how it sits now, plus some trimming and bashing, should be plenty.
Old 12-11-2006, 04:26 AM
AH64ID's Avatar
Dont forget the width, unless your going to run the 35x10.50 SSR.. the width will cause more issues than the height... with no suspension lift it will probally take a 3" BL to clear 35's...
Old 12-11-2006, 09:28 AM
AxleIke's Avatar
I'm not sure if you do any offroad travel, but if you do more than just dirt roads, 35's will be seriously pushing the limits of the strength of your front drivetrain. On a first gen 4runner, you almost certainly will start breaking CV's, unless you are very very light on throttle. You'll also have issues with your steering pretty badly.
Not saying that you shouldn't do it, but just something to keep in mind.
Old 12-11-2006, 01:43 PM
Numbchux's Avatar
I'm already running 12.5" wide tires....and the truck needs some fender trimming anyway (a bunch of rust around the fender wells...)
my last wheeling rig was a 4" lifted subaru station wagon. I'm used to being gentle.
Old 12-11-2006, 03:33 PM
  #25
AH64ID's Avatar
I have 35's on my 92 and they drive much better than the 33's I had on my 95, there is no pull or funky road manners at all...
As far as the CV's it depends on how you drive... you can drive smart and never break one...
Old 12-11-2006, 05:22 PM
  #26
tc
tc's Avatar
Unfortunately, common sense ain't so common ...
Old 12-11-2006, 06:02 PM
  #27
Flygtenstein's Avatar
Drive smart and never break one?
Not buying that.
I drove easy, strapped when I needed, winched when I needed. I killed stuff when I was taking it easy. Times when I was being bad and expected a big pop would mostly be uneventful.
If you need 35's, you need to know how to fix stuff because you ought to have the truck on trails where you are using the snot out of it.
Old 12-11-2006, 07:17 PM
  #28
toyotaoffroad91's Avatar
this is my old 91 its a 4" bracket suspension lift and a 3" Bl as you can see you dont need that much BL i was young and stupid id do a 4" lift with a 1 BL or even BJ spacers
rondogracing
07-05-2015 12:32 AM
Gamble_STi
07-01-2015 12:51 PM
BigArt70
06-30-2015 09:51 PM
LSUMatt1514
60
10-10-2003 12:30 PM
HALMAN
06-14-2002 09:02 PM
Quick Reply: Lift needed for 35 inch tires
