hi-lift cheap trick
Old 05-02-2005, 08:18 AM
shiftless89's Avatar
hi-lift cheap trick
OK, I was about to stash my hi-lift in my truck after I put the isolater on it I picked up from Central. When I dug for a wrench to remove the end shackle at the top of the jack I found it to be a SAE nut-bolt. I thought about the tools I take on the trail and they are all metric.. so the wheels start to slowly turn, I scounge in my bolt bin and I find a metric bolt with a 19mm head, fits perfect and works with the tools I cary. If you ever have to use your jack as a clamp, make sure you have the tools to work on it.
Mike
Old 05-02-2005, 10:48 AM
Jake94's Avatar
Not as cheap, but infinitely better:
http://www.rescue42.com/off-road.htm
Jake.
RobotMoose
02-22-2020 07:44 AM
pickle6415
10-19-2015 08:08 AM
JookUpVandetti
09-30-2015 08:58 AM
93RedKrawler
09-25-2015 04:03 AM
Buckaroo_Banzai
09-24-2015 07:26 AM
Quick Reply: hi-lift cheap trick
