Do i need to beef up my frame for winching
Old 02-21-2013, 07:20 PM
Wildcat4R's Avatar
95 T4R, 3.0, 4x4, 5 spd. Mile marker sec8000 winch.
I have a 4xinnovations winch bumper on now. It has the "frame tie in plate". It only has 4 bolts on the front cross member and one bolt on each side mount. Is this enough for winching? I thought about fabbing a bracket that attaches to the 4 threaded holes under the frame and tie that into bumper. Am i over thinking this? Are 4 bolts on the front cross member enough? I am using grade 8.8 bolts.
Old 03-15-2013, 05:05 PM
86reaper's Avatar
If you weld that reinforcement brace to the front of your frame, ultimately unifying the left, right, and middles pieces of the frame, you should be able to hang that truck in a tree by the front bumper...
Old 03-16-2013, 03:52 AM
wyoming9's Avatar
Red face
Have you talked with Adam??
I am sure he can tell you just what you need to do
To me one can`t have to many attachment points if your getting into some heavy duty recovery work.
I always make my own crossmember that attaches to where the front hook and tie downs are.
Old 03-16-2013, 06:02 AM
Fossilized
Staff
dropzone's Avatar
X2 on getting with Adam about this..He has given me great customer support
Old 03-19-2013, 05:43 PM
Wildcat4R's Avatar
That was no help. When i emailed and called about fitment issues i was told it should bolt right up. I had to add 1" of steel to get the bumper out enough to mount the winch. When i emailed those pics.....no reply. Its a shame too cuz i WAS gonna buy his rear bumper.
I will prolly get the reinforcement plate from addicted and weld it on. Then bolt this all back up.
Old 03-24-2013, 11:16 AM
VSIXFOURunner's Avatar
Don't know if this help.but this is how I did my winch Mount.I added some side mounts. For more Support.
Old 05-06-2013, 07:26 PM
travisliam's Avatar
^ is that the only mounting spot or is there more? (sorry im new to this)
justdifferentials
14
06-11-2017 08:36 PM
I8URSVT
04-17-2016 03:38 AM
indawire
11-29-2015 05:05 AM
urabus
11-10-2015 07:38 PM
justdifferentials
09-05-2015 06:52 PM
Quick Reply: Do i need to beef up my frame for winching
