budbuilt skids and bolt heads
Old 04-05-2006, 04:00 AM
Senior Member
jacksonpt's Avatar
For those of you who are running budbuilt skids, are the bolt heads exposed? If so, is there concern about they getting trashed and no longer being able to remove the skids?
They are the leading contender for my 96 4Runner.
Old 04-05-2006, 04:09 AM
Intrepid's Avatar
I don't have one, so I could be wrong, but I thought all the holes were countersunk w/ allen head bolts so that they it flush...I know his crossmember is made like that.
Old 04-05-2006, 04:17 AM
Senior Member
jacksonpt's Avatar
from the pics I've seen, that appears to be the case. But if not, that's a problem for me and would likely cause me to go with someone local for custom made skids. I just want to be sure...
Old 04-05-2006, 04:46 AM
bamachem's Avatar
they are counter-sunk. check out the pics here (there's plenty): https://www.yotatech.com/forums/show...8&page=1&pp=40
better hurry if you want to save some MAJOR bank!
Old 04-05-2006, 09:07 AM
vegaskurt's Avatar
The allen bolts on the skid are recessed. The belly pan ones are not. But the heads on them are smooth so I would not loose much sleep over them.
Old 04-05-2006, 03:09 PM
00Runner's Avatar
It looks like you had some issues with gas tank interference on the belly skid. How did you fix it?
Old 04-05-2006, 03:12 PM
Localmotion's Avatar
I wonder if these will work with Steve Shaffers old belly pan. :pat:
Old 04-05-2006, 03:14 PM
garrett1478's Avatar
make it work :pat:
Old 04-05-2006, 03:15 PM
Originally Posted by garrett1478
make it work :pat:
too much effort....read the sig!!!!
Old 04-05-2006, 05:17 PM
anyone
Old 04-06-2006, 12:13 PM
vegaskurt's Avatar
Bud bent the trailing edge of my belly pan way up. I figure he does this for tacomas and he forgot it was for a 4runner. He appologised and offered to pay for it to be shipped back but since I had already painted it I just took a cut off wheel to the bent up edge.
kgcwb44
01-29-2023 10:02 AM
BeMiceElf
10-10-2015 09:40 PM
88sasturbotoy
08-11-2015 01:56 AM
Gone Fission
07-24-2015 12:49 PM
whereAreMyPants
07-22-2015 03:32 AM
Quick Reply: budbuilt skids and bolt heads
