ac compressor conversion for onboard air
Old 09-08-2008, 09:08 PM
supercharged98's Avatar
is there any one that knows how to do this with a toyota ac compressor. i have looked around on the net and the only thing i can find is the york compressor mod. any help would be really appreciated
Old 09-08-2008, 09:09 PM
ozziesironmanoffroad's Avatar
search button works now...
Old 09-08-2008, 09:20 PM
thanks you are really helpful
Old 09-08-2008, 09:29 PM
corax's Avatar
you need to plumb an inline oiler on the suction side and an oil separator on the discharge side to remove the oil you put in. That way the compressor doesn't burn up (in an A/C system, the freon holds the lubricant in suspension, this is how the compressor is lubed). The rest is pretty much the same as a York install - pressure switch, relief valve, etc.
Old 09-09-2008, 05:56 PM
thank you for the help that is all i was really looking for. i just wanted to make sure that there was not something else special that i needed to do.
Old 10-22-2010, 05:06 PM
4x4Burro's Avatar
Very cool, I have a 85 22re thats turning into a rock crawler and this would be a great mod for the truck. I too have the stock A/C compressor, this might sound like a dumb question but what side is the intake side? A picture would be a great help for me(I'm a visual learner).
Old 10-22-2010, 06:09 PM
86tuning's Avatar
The cheap way is to put an air filter on the inlet, and simply squirt some oil into the intake before you go 4wheeling. ATF works fine, as does any air-tool oil, or air-compressor oil. 1/2 teaspoon is more than enough to run the compressor for 1/2 hour, which will fill a dozen tires.
I manually oil mine. Works fine.
I use the VIAIR 85/110psi switch to control my compressor, and have a 2gal tank plumbed in, with a proper petcock for draining the tank after each use. A 150psi blow-off (safety) valve is on the tank, as well as the inlet/outlet fittings.
As long as your air chuck is after the tank, the tank will collect all the oil that goes thru the compressor. Which isn't much. A bit of oil mist comes out when I purge the tank after each use. Not a big deal.
Plumbing the air tank can be done with fuel piping and flare fittings, or you can do it with DOT plastic hose and push-fittings. Mine is heavy duty with 5/8 aluminum fuel pipe & AN fittings.
If your air chuck isn't in a clean spot, you can use plastic covers for hydraulic fittings to keep the dirt off. But it's best to put the fitting in a spot that doesn't get too dirty, and is convenient. One day I'll plumb a second air chuck on the other side of the truck. haha.
Old 10-22-2010, 08:41 PM
4x4Burro's Avatar
Thanks 86tuning for the info looks like I have a fun project to do this weekend.
Old 10-22-2010, 08:48 PM
BigBluePile's Avatar
On my list too!
Old 10-24-2010, 02:56 AM
91 4Runner's Avatar
Mine too, just need the AC for a 22re
mussy01
12-13-2016 08:20 PM
RatOmeter
10-22-2015 03:17 PM
94ofCanada
08-14-2015 06:37 AM
calderp
07-27-2015 09:58 AM
skoti89
07-08-2015 12:05 AM
Quick Reply: ac compressor conversion for onboard air
