22r engine help
Old 09-09-2004, 07:41 PM
forty4's Avatar
22r engine help
ok, how do i get more power out of this 22r 4 banger. i got the sr5 model. the only thing i've done to improve it was cut off the muffler and put a straight pipe through it. what about removing the air conditioning unit and replacing cap and wires and plugs. how much hp is lost to that fan? any help here would be appreciated. or websites that i could look on for info. i also heard something about running these engines on propane. that might be down the line if i ever figure out how to do it.
Old 09-09-2004, 08:27 PM
colsoncj's Avatar
From my experience, the only reason I know of (someone else might offer more insight) that people run off-roaders with carburetors on propane is to traverse steep inclines. With a carb, on a big incline, the bowls can empty out and the floats won't let them fill up because of the incline, which the propane induction solves.
As far as more power, breathing is the name of the game, more air in, more air out, more power. More flow in through better air induction and more flow out through that staright pipe should help a little. Getting rid of accessories always helps. An easy fix for the A/C drag is if the belt only runs the compressor, take it off and that takes care of that. No more power loss and all the A/C components are still there, should later you decide you do want air. A fan if I remember correctly sucks about 5 hp out of a motor. Thats a rough guess, so don't hold me to it.
A tune up, if it hasn't had one in a while will always help. Cap and rotor, plugs and wires, if needed, can give a vast improvement in power. Remember to change the air filter too. I worked on a 94 4Runner with the dirtiest air filter I had ever seen. Changed it and saw not only a little more umph but 5 mpg better at the pump.
Hope some of this helps!
Old 09-09-2004, 08:30 PM
jimbo74's Avatar
www.lcengineering.com www.downeyoff-road.com check those out....
Old 09-09-2004, 09:22 PM
Shane's Avatar
Depends on the design of the carb. Some will overfill the bowl(s) and flood the engine.
You can't get too much extra power out of a 22, unless you move up to forced induction. Your next choice is an engine swap.
Old 09-09-2004, 09:34 PM
colsoncj's Avatar
Good call Shane, thanks for the help, either condition, if I remember correctly, the propane allows you to keep on runnin at any incline.
I also agree with Shane, without forced induction or other real expensive mods, your not going to get too much out of it. If you want some power, and have a bit of money to spare, search on the forum for a 7mgte swap or something similiar. I remember seeing a thread about someone who swapped one in.
sandyota
02-04-2021 11:16 AM
Seattle_Sign_Guy
07-12-2015 12:38 PM
cars-guy
07-11-2015 07:51 PM
Tyler Cunningham
07-11-2015 10:18 AM
87blyota
07-10-2015 04:31 AM
Quick Reply: 22r engine help
