tundra TPS sensor
tundra TPS sensor
can somone tell me the specified resistance values for the throttle position sensor on the 2000 tundra. I dont have the book and this is all i need to know. thanks.
Originally posted by alexg1323
thanks
thanks
Anyway, the manual accord to SF-31, states that for the 2UZ-FE engine (V8), the resistance is 1.25-2.35 kOhms at 20C (or 68 F) in between terminal VC & E2. If you need me to fax over where the measurement needs to be taken off the terminal, pm me with a valid fax number.
Oh almost forgot, if you need the 5VZ-FE (V6), it indicates to add vaccum to throttle opener and measure resistance on terminal for
1) Fully closed - between VTA & E2 - 0.2-5.7 Kohms
2) Fully open - between VTA & E2 - 2.0-10.2 Kohms
3) unknown - between VC & E2 - 2.5-5.9 kohms
Yea i need the resistance range for the throttle position sensor on the V8 i know it must be off i keep getting a CEL for intermediate and high voltage from the TPS. If you can give me the opened, closed, and installed ohm ranges for the V8 id be much indebt thanks a bunch
I look again tonight, but I think that's all that was in the manual.
Need the ohm rating for the 4.7 V8 tps 2000
What is the ohm setting and idle voltage for the 4.7 l V8
2000 Toyota Tundra? Please and thank you. Can't seem to find information on this anywhere
Blamalam
03-12-2022 07:34 AM
Blamalam
08-16-2015 12:29 PM
