99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 Late model full size trucks and SUVs
Help With Error Codes - Specifically P2410
Old 07-23-2013, 06:35 PM
trbbhm's Avatar
I am hoping that someone can help me figure out how to fix these codes on my Sequoia. I'd like to do the work myself and save a few $$$. I had a Toyota repair shop pull the codes from my '06 Sequoia Limited and they came up with the following:
1 - P0031 (O2 sensor #1 bank 1)
2 - P0051 (O2 sensor #1 bank 2)
3 - P0441 (Incorrect Purge Flow)
4 - P0446 (Evap Vent Control Circuit)
5 - P0430 (Catalyst Bank 2)
6 - P2410 (Switching Valve Open)
Codes 1 & 2 I can fix by replacing the O2 sensors.
Codes 3 & 4 I *think* can be fixed by replacing the vacuum switching valve (
Dorman 911-601 Toyota Vacuum Switching Valve : Amazon.com : Automotive Dorman 911-601 Toyota Vacuum Switching Valve : Amazon.com : Automotive
Code 5 I *think* is associated with codes 1 & 2??
I'm confused by code #6. Searching the internet does not lead to a definitive match on the specific code (2410). Similar codes (and a text search on "switching valve open") lead me to believe that this is associated with an air switching valve?? (
ACDelco 214-2151 Air Check Valve : Amazon.com : Automotive ACDelco 214-2151 Air Check Valve : Amazon.com : Automotive
Again, I'm hoping that a more experienced someone can tell me if I'm close on my assumptions and can help me get this fixed without having to take it to a dealer or mechanic.
Thanks!
Old 07-23-2013, 07:08 PM
rworegon's Avatar
I found:
P2410, Fuel Cap Sensor/Switch Circuit Low
You might try a new gas cap or just replace the current gasket in the cap.
Old 07-24-2013, 04:50 AM
trbbhm's Avatar
Boy, wouldn't it be great if it were that simple! I'll give that a try and repost the results.
Also, if anyone else can comment on my approaches with the other codes, I would be most grateful!
Old 08-19-2013, 08:07 PM
kuzbro's Avatar
All those codes doesn't mean all those systems have problems, one may cause another to trigger. Not on a Toyota, but I had a stuck EVAP system valve on a Nissan and just cleaned it up, used some type of lube on it (can't remember what type) and it worked for another year or so. When the code reappeared again, I replaced the valve with a new one. (OEM).
If you are going to do your own work, I suggest getting your own code reader and a good multi-meter, (Fluke is best).
moparbay
03-10-2023 03:50 PM
some drunk guy
08-03-2021 06:09 PM
mbomberz1
10-09-2015 07:17 PM
Armstrong486
09-19-2015 12:37 AM
Quick Reply: Help With Error Codes - Specifically P2410
