99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 Late model full size trucks and SUVs
battery with blue crust on negative?
Old 11-20-2004, 08:26 AM
slyang1012's Avatar
guys.. im rewiring my hellas for the rear.. and when i openned my hood.. theres this blue crust on the neg and some on positive.. is there anything wrong?.. i hoooked it up iwth the instructions it came with.. and it works fine... i drove with them on for a long time when i was up in arizona.. but the blue crust???? anyone .. thanks
Old 11-20-2004, 01:59 PM
BigA's Avatar
The blue crust is oxidatoin. The best way to take care of it is to mix baking soda and water and pour it on the battery. Let it sit for a few then scrub off with a tooth brush. Or you could just take your coke out of the cup holder and drench it in that stuff (it will do the same thing). Once you do that take some dielectric grease and smere it on the terminals.
Andrew
Old 11-20-2004, 10:08 PM
slyang1012's Avatar
Andrew
hmm.. thanks!!.. do you know y that happeneds??
Old 11-21-2004, 09:23 AM
BigA's Avatar
Its a common thing, its just a little bit of corrosion. All batteries are capable of doing it. If you coat the terminals with the dielectric grease, the corrosion will stop. And just keep the terminals clean and greased and they will stay happy for a long time.
Andrew
Old 11-25-2004, 06:44 AM
BigStew's Avatar
It is funny how some batteries/vehicles tend get that corrossion more than others. I have had real good success with those red and green felt pads that go under the terminal, put them on and no more corrosion. They cost a couple of bucks and are available at any parts store.
Old 12-01-2004, 04:34 PM
Kookadala's Avatar
Get a gel-cell sealed battery and no worries anymore. The corrosion is due to leaking acid or vapors from the battery. Dont wheel with a regular battery or you are asking for trouble and/or injury. Make sure you wear safety glasses when you clean the terminals as acid residue in your eyes hurts like all get out.
Chicken12
10-14-2015 03:54 PM
Obmi
10-04-2015 11:30 AM
zombie_barbarossa
10-02-2015 10:54 PM
JPV
09-28-2015 03:15 PM
charlie_fong
09-27-2015 10:06 PM
Quick Reply: battery with blue crust on negative?
