99+ Tundra, 00+ Sequoia, 98+ Land Cruiser/LX470 Late model full size trucks and SUVs
02 Sequoia - Wiring Colors (missing harness) B2S2 Oxygen Sensor
Old 10-20-2011, 01:37 AM
gt2av8's Avatar
Hi all,
I"ve bee doing some work on a Sequoia for a family that I'm friends with. Long story short, it had all 4 O2 sensors replaced last fall, yet throws heater circuit malfunctions for all. Well, the report I got is that the shop said they "couldn't get them wired right." Last week when I did brakes on it, I crawled around to find that they used all Bosch sensors, which I get the idea Toyotas don't play well with. So, there's my answer. Here's my problem...
The wiring for the bank 2/sensor 2 they chopped out all the way from the sensor up to the (inch and half or so thick) wire wrap at the top rear of the engine. They replaced the inbetween wire with 4 identical black wires. So, I have no idea how to match the colors for the new sensor (I'm replacing all 4 with OEM Denso sensors).
From what I've been able to tell, the wiring harness that would have been there would have had...
Blue - signal
White - heater
Brown - heater
Gray - Ground
So, here's what the approx 3 inches of wire coming from the wrapped section are (which are then spliced to the blacks and spliced again to the sensor)...
Color with color stripe (unsure of color)
An off white/cream/yellowish funky color
White - and this one is a heavier gauge than the others.
Any ideas?
If I can't get the color matches, I could somehow test them with a multimeter, right? If the ECU is coding them all w/ heater circuit fault though, will it try to use them or are they cut off? (I don't have a scanner to reset, and if I go to the store to reset it, it'll have the codes again by the time I get back with it).
Thanks, all!
icentropy
09-16-2020 02:47 PM
09-04-2015 09:27 AM
msane99
07-17-2015 10:13 AM
88yodabasket
07-13-2015 01:32 PM
Suprarossa
07-06-2015 05:21 AM
Quick Reply: 02 Sequoia - Wiring Colors (missing harness) B2S2 Oxygen Sensor
