Stage Series Reverse Light Kit for 2022 Toyota Tundra | Diode Dynamics
Old 01-31-2023, 12:38 PM
Sponsor
Diode Dynamics's Avatar
Stage Series Reverse Light Kit for 2022 Toyota Tundra | Diode Dynamics-fnd70rn.jpg
Diode Dynamics is excited to introduce our Stage Series Reverse Light Kit for the 2022 Toyota Tundra!
Overview Video (Coming soon): https://www.youtube.com/diodedynamics
Stage Series Reverse Light Kit for 2022 Toyota Tundra | Diode Dynamics-vvyw5la.jpg
This kit is available with our SSC1 Sport/Pro or SSC2 Sport/Pro LED Pods
There's plenty of ways to add light behind your Tundra, but the new Stage Series Reverse Light Kit stands out with innovations in both function and ease of use. This kit includes an integrated red running light, and plug-and-play wiring harness, for trouble-free installation! Thanks to Stage Series TIR optic technology, this kit provides a huge amount of extra reverse light. The included switch allows you to toggle it on any time, or activate it automatically with your reverse lights, for a truly integrated solution.
Stage Series Reverse Light Kit for 2022 Toyota Tundra | Diode Dynamics-xy5zjl6.jpg
Plug and Play. Thanks to custom-molded OEM connectors, this kit is completely plug-and-play. The included adapter harness plugs right into your factory trailer hitch wiring for easy installation and operation. No cutting, drilling, or additional wiring needed! The kit operates as an additional red accent light, with your tail lights, and then automatically switches to a high-power backup light when your vehicle is in reverse. If you would like to have override functionality to manually turn on the main beam anytime, you will need to purchase the universal universal backup harness.
In the Box:
  • Two (2) SSC1 or SSC2 Standard LED Pods
  • One (1) Trailer Reverse Light Wiring Harness
  • Mounting hardware
  • Installation guide
Backlight Functionality. The Stage Series LED pods included with this kit feature a distinctive backlight in a vibrant red color which functions as an additional accent light while driving! The backlight fully illuminates the TIR optic, providing a more unique and modern look than the small indicator LEDs found in other products.
Stage Series Reverse Light Kit for 2022 Toyota Tundra | Diode Dynamics-d75bzez.jpg
Focused. Traditional optics like reflectors or simple lenses lose light internally and to glare, so not all of the light shines on target. Instead, the custom-engineered TIR optic in our Stage Series pods collects all of the light from the LED, and directs it only where you need it, drastically reducing glare and improving total efficiency.
Stage Series Reverse Light Kit for 2022 Toyota Tundra | Diode Dynamics-8lkq3tt.jpg
SSC2 Pro LED Pods w/ Flood Optic
Functional Patterns. All Stage Series beam patterns were designed with optical simulation modeling, to shape the output in a highly-functional beam pattern.
  • Flood pattern was designed to provide uniform, even illumination with a full 50x50 degree spread of light on the SSC1 LED pod, and a 60x60 degree spread on the SSC2 LED pod. Unlike generic "flood" lights that are simply a heavily diffused spotlight, our flood pattern uses pillow optics on the outer lens surface, to provide a true optically designed spread, for even illumination throughout.
Sport or Pro. Stage Series LED pods are available at two different power levels. Both options use high-intensity LED emitters, and TIR optics for unmatched focus and overall output. However, the Pro option is double the amount of total power. Click the Specifications tab to see more information!
Stage Series Reverse Light Kit for 2022 Toyota Tundra | Diode Dynamics-zf4bb60.jpg
Proven Reliability. Stage Series LED lighting has been extensively tested for long-term operation from -40 to 185 degrees F, along with vibration, moisture intrusion, and corrosion testing. All of these tests are completed to SAE standards, just like factory components. They've also been put to the test on-road by racers and enthusiasts alike.
If you have any questions, we'll be more than happy to help!
Monday-Friday 10 a.m.- 5 p.m. CST
Email: contact@diodedynamics
Phone: 314-205-3033
Did you know? All US forum members are eligible for a FREE SHIPPING code! Just send us a direct message.
John C.
Diode Dynamics
Quick Reply: Stage Series Reverse Light Kit for 2022 Toyota Tundra | Diode Dynamics
