SS5 Stealth Grille LED Pod Kit for 2014+ Toyota 4Runner | Diode Dynamics
Old 01-26-2023, 10:32 AM
Sponsor
Diode Dynamics's Avatar
Lightbulb SS5 Stealth Grille LED Pod Kit for 2014+ Toyota 4Runner | Diode Dynamics
SS5 Stealth Grille LED Pod Kit for 2014+ Toyota 4Runner | Diode Dynamics-olsq4fs.jpg
Diode Dynamics is excited to introduce ourStealth Grille LED Pod Kit for 2014+ Toyota 4Runner!
Perfect Fitment. The SS5 Stealth Grille LED Pod Kit for the 2014+ Toyota 4Runner from Diode Dynamics allows you to mount two or four Stage Series 5-inch LED pods behind the factory grille without interfering with the Toyota Safety Sense! These application-specific brackets were CAD-designed to bolt into place using factory mounting points on the factory bumper. No cutting or drilling required! This kit retains the factory grille for a clean, OEM-like appearance.
Choose Your Look. The brackets included with this kit were designed for full customization. They feature multiple mounting holes, so you can mount two or four SS5 LED pods behind your grille and achieve the look you're after. The best part is this kit will not interfere with the Toyota Safety Sense!
SS5 Stealth Grille LED Pod Kit for 2014+ Toyota 4Runner | Diode Dynamics-e8ua8zq.jpg
If your 2014-2019 Toyota 4Runner does not come equipped with Toyota Safety Sense, you have the option to mount an additional fifth SS5 LED Pod Light in the center of the crossbar for even greater output.
SS5 Stealth Grille LED Pod Kit for 2014+ Toyota 4Runner | Diode Dynamics-axxiadt.jpg
Designed for Performance. Featuring the highest output intensity of any 5-inch LED pod on the market, these auxiliary lamps have been designed for maximum functionality, with patented technology and custom-engineered TIR optics, all in a durable package.
SS5 Stealth Grille LED Pod Kit for 2014+ Toyota 4Runner | Diode Dynamics-geekhch.jpg
From there, while other options on the market lose as much as 10% of the light output shining through an outer lens, the custom-molded TIR optic in the SS5 serves as both the optic and main lens for greater efficiency and light output. Thanks to this patented and innovative technology, when coupled with high-intensity LED chips, the total intensity of the SS5 is much greater than other LED pods using basic optics or reflectors with a standard outer lens.
SS5 Stealth Grille LED Pod Kit for 2014+ Toyota 4Runner | Diode Dynamics-wn96e7c.jpg
Selectable Backlight. The Stage Series 5" LED Pods included in the White kit feature a selectable backlight with eight different color options, perfect for an extra styling accent, or for more visibility when you’re not using the main beam. Selecting your backlight color is easy - simply alternate the power on and off. There’s no complicated programming with a controller! The SS5's backlight fully illuminates the TIR optic, providing unique accent lighting that you won't find on other LED pods.
SS5 Stealth Grille LED Pod Kit for 2014+ Toyota 4Runner | Diode Dynamics-0ueixi1.jpg
NOTE: Due to the yellow lens, the Yellow kit is only available with an Amber backlight color.
Click HERE to check out the SS5 Stealth Grille LED Pod Kit for the 2014+ Toyota 4Runner!
SS5 Stealth Grille LED Pod Kit for 2014+ Toyota 4Runner | Diode Dynamics-jx1trzo.jpg
SS5 Stealth Grille LED Pod Kit for 2014+ Toyota 4Runner | Diode Dynamics-uox51d0.png
Functional Output. Stage Series beam pattern options were designed with advanced optical simulation modeling, to shape the output in highly-functional beam patterns with high efficiency.
  • Combo pattern combines both the Driving and Flood optics, perfect for all-around use. It shines light downrange in a focused 30x20 Driving beam to punch with distance, and fills in the surrounding area to create a full 70x30 degree pattern. With a row of driving optics in the middle, and a flood optic on the top and bottom, this has been designed to provide extra light for every situation.
  • Driving is great for general illumination at speed. Rather than a traditional "spot" pattern, the Stage Series Driving pattern shines in a 30x20 degree spread, providing just enough width to fully illuminate the road ahead at high speeds, but still staying focused to avoid too much foreground light. Although the SS5 Driving is too bright to be considered an SAE Auxiliary High Beam, it is perfect for an extra boost of light at speed.
White or Yellow. This kit is available in a cool white or selective yellow color. The white is a 6000K color temperature, which is a true cool white output, and matches most factory LED lighting. The selective yellow is a 3000K color temperature, great for high contrast in poor weather or a distinctive look on the road.
SS5 Stealth Grille LED Pod Kit for 2014+ Toyota 4Runner | Diode Dynamics-4peqgvd.png
Sport or Pro. This kit is available at two different power levels. All options use high-intensity LED emitters, and TIR optics for unmatched focus and overall output. The Sport model uses nine high-intensity LEDs for 40W of total power. The Pro model steps things up in a big way, with double the total power at 90W.
SS5 Stealth Grille LED Pod Kit for 2014+ Toyota 4Runner | Diode Dynamics-m4pth3x.jpg
Two-Pod Kit:
  • Two (2) Stage Series 5-inch LED Pods
  • Two (2) Application-specific heavy-duty steel brackets for installation on 2014+ Toyota 4Runner
  • One (1) SS5 Crossbar Mount for installation on 2014+ Toyota 4Runner
  • One (1) Heavy-Duty Dual-Output Wiring Harness
  • Installation Guide
SS5 Stealth Grille LED Pod Kit for 2014+ Toyota 4Runner | Diode Dynamics-xrhalbp.jpg
Four-Pod Kit:
  • Four (4) Stage Series 5-inch LED Pods
  • Two (2) DT 4-Pin Splitter Harnesses
Interchangeable Lens. Need a different beam pattern or color? You can swap it yourself! We offer replacement lenses that allow you to change the color or optic of your Stage Series SS5 Pods.
SS5 Stealth Grille LED Pod Kit for 2014+ Toyota 4Runner | Diode Dynamics-jzhr9gf.jpg
Snap-on covers. For states that require them, we also offer snap-on covers for your SS5 Pod. These covers are available in a variety of colors and keep your SS5 Pod clean and protected from dirt, dust, or whatever else the road throws your way!
SS5 Stealth Grille LED Pod Kit for 2014+ Toyota 4Runner | Diode Dynamics-pkwqrjo.jpg
Proven Reliability: Stage Series LED lighting has been extensively tested for long-term operation from -40 to 185 degrees F, along with vibration, moisture intrusion, and corrosion testing. All of these tests are completed to SAE standards, just like factory components. They've also been put to the test on-road by racers and enthusiasts alike.
If you have any questions, please don't hesitate to post, PM, or email contact@diodedynamics.com.
PM us for the free-shipping code (U.S. forum members only)
John C.
Diode Dynamics
Old 01-27-2023, 07:39 AM
Sponsor
If you haven't seen the installation video in our thread, here is a great behind-the-scenes shot of our 2-pod, 4-pod, and 5-pod configuration!
SS5 Stealth Grille LED Pod Kit for 2014+ Toyota 4Runner | Diode Dynamics-xo3muif.jpg
SS5 Stealth Grille LED Pod Kit for 2014+ Toyota 4Runner | Diode Dynamics-5rn4nmo.jpg
SS5 Stealth Grille LED Pod Kit for 2014+ Toyota 4Runner | Diode Dynamics-6c71k5f.jpg
Which would you pick?
Quick Reply: SS5 Stealth Grille LED Pod Kit for 2014+ Toyota 4Runner | Diode Dynamics
