Early Land Cruisers All solid front axles and Land Cruiser series - 25, 40, 45, 55, 60, 62, and 80
need the trick to get the #1 oil pan out on my '93 fzj-80
Old 07-26-2012, 02:44 PM
Diverdoll's Avatar
I have the #2 oil pan off and the stabilizer bar off plus drivers side bracket. Now the front of the pan is hanging up on the first piston bearing cap. I cant come down any more (away from the block) because the cross bar that is part of the track bar assembly that can't be removed because its welded at both ends. I'm sure I'm missing something simple but its still eluding me :-\ I really need to get to my bearings so I can get back on the road.
thanks! :-)
Old 07-26-2012, 09:16 PM
rokblok's Avatar
Without seeing one in person, is it possible to remove engine mount bolts and lift the engine enough to accomplish what you need?
okamikai
04-30-2018 10:19 PM
09-04-2015 09:27 AM
thefishguy77
07-30-2015 10:59 AM
irritech
07-27-2015 05:15 PM
toofly1999
07-25-2015 07:09 PM
Quick Reply: need the trick to get the #1 oil pan out on my '93 fzj-80
