Early Land Cruisers All solid front axles and Land Cruiser series - 25, 40, 45, 55, 60, 62, and 80
landcruiser's with locking dif
Old 04-01-2013, 07:58 PM
jrami542's Avatar
Ok know knowing that can some body tell me how good are the spartan locks??? And thanks for getting me out of doubt??
Old 04-02-2013, 12:08 PM
snobdds's Avatar
Not really. Its still called a diff lock.
I disagree...
I am shopping for a 80 series landcruiser. Suppose I ask a seller if the "diff" is locked, and he responds by saying yes. I then drive 300 miles to check said cruiser and the diff is not locked, only the center diff is locked. Symantics are in the details...Ask me how I know?
In the landcruiser world, diff means axles and center diff means transfer case.
Old 04-02-2013, 02:16 PM
highonpottery's Avatar
on a cruiser it's still called a "center diff lock/CDL" regardless of it actually being the t-case, and it simply locks the f/r t-case outputs supplying 50:50 power vs the 60:40 (or whatever it is) it was when in normal driving mode. has nothing to do with the axle differentials.
in regards to asking a seller if diff is locked....unless they have a clue, i'd say most consumers don't know what this means since they've never used it. you need to ask if the rig has front/rear lockers and whether or not there's a button/dial on the side of dash for f/r diff lock.
Old 04-02-2013, 02:34 PM
snobdds's Avatar
Originally Posted by highonpottery
on a cruiser it's still called a "center diff lock/CDL" regardless of it actually being the t-case...has nothing to do with the axle differentials.
I will only add, center diff lock can only mean the transfer case.
Old 04-03-2013, 08:05 PM
  #25
BigBluePile's Avatar
One could assume that.....
Old 06-13-2013, 01:30 PM
  #26
masterfab23's Avatar
My lockers did not engage and my tc didn't lock either, took me switching from hi to low a thousand times. I got lucky that I didn't have to dig into them.
ladybugRC
458
08-21-2020 10:41 AM
PNW94Runner
09-29-2015 02:55 PM
toyotasaurus
09-24-2015 03:30 PM
ToyotaMD
09-22-2015 06:28 AM
Quick Reply: landcruiser's with locking dif
